Ryobi 18v BCL14181H MY2015 charger dead
    Re: Ryobi 18v BCL14181H MY2015 charger dead
    If I remember correctly, they both blink once after the charger is plugged in and then the red led stays on.
    Now they are just blinking.
      i asked because i have some radio chargers that alternate really fast between red & green when the radio is not connected.
        You are correct about what is suppose to happen when you first plug it into the outlet I have one that is doing this and I have not figured out what is causing this issue
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          I guess you have replaced almost every component on that charger...?
            The only real issue you might have is if the micro controller ic chip goes bad buy a new charger
            9 PC LCD Monitor
            1 Dell Mother Board
              Yea, I have another charger.
              But I'd like to have this one fixed. New charger costs less than what I've spent on spare parts... d'oh.
