A question about PWM IC's
    Re: A question about PWM IC's
    Originally posted by R_J View Post
    Just a note on the source resistor, it should be a non-inductive type once you do the final repair. Also without a load on the power supply, the circuit may start but be in burst mode until a load is placed on the secondary. This is a complex, green mode ic, and the circuit operates at high frequency. The whole circuit is fairly simple as the ic does a lot of the work, I suspect and hope the ic should fix the smps.
    Nice one for the heads-up on those points.
    I was unware on 'non-conductive' resistors, so that is for sure good to know.
    There are three different ones here, two are wire-wound, one a fat, green 5W affair and the other looking like a wire-wound carbon.
    The third is a square-edged, white ceramic axial, 2W
    Looking into it, some non-inductive resistors have an extra yellow band, which none of these have. I'll see if I can't get back to the shops today.
      Originally posted by keeney123 View Post
      As a last thing I can point you to in understanding this circuit and others is this site.
      https://training.ti.com/pulse-width-...pwm-converters
      I find the free ti training course offer a good fundamental understanding.
      Cool.
      Thank you for your patience.
        Thanks for posting this website link for this type of information
        Very informative information
        9 PC LCD Monitor
        6 LCD Flat Screen TV
        1 Dell Mother Board
        15 Computer Power Supply
        All of these had CAPs POOF
          I once took an amplifier source from them for free. At the time they actually gave you a test and they graded it. So, your welcome.
            Most non-inductive resistors have a black band as the last band
            In this case I would just use a metal oxide type resistor, like a MOSX2CT52RR12J 0.12Ω/2watt from digikey
              The shops were all shut on saturday due to Carnival, but are you saying that this will cause the unit to fail?
              Digikey is a long way from here and the 40 USD postage is too much, so it'll have to be something else, at least for now, until I get back to Europe.
              The new chip is installed, and only the source resistor remains.
              Can the PSU not be switched on for a short period of time, just to verify, or is it absolutely critical to use non-inductive resistors on the source of the switching Mosfets?
                Any resistor should be ok for the source resistor, being such a low value I doubt there would much inductance in even a wire wound resistor. So you should be ok.
                The part number I gave was from digikey KOA Speer electronics, but any supplier should be able to provide a suitable resistor
                  So here is an insight to wire wound resistors.
                  https://eepower.com/resistor-guide/r...und-resistor/#
                    A quick update.
                    I replaced the Ic and used a 0.12 ohm ceramic resistor and switched it on.
                    No 24V DC output and no frequency on the gate pin of the IC.
                    Unfortunately I had been using hooks to measure the FET voltages and even though it was switched off, I hadn't waited for the filter caps to discharge before removing them which shorted it out, so until I get a replacement FET there is not a lot else to report.
                    All invaluable lessons, although I am now short of ideas on resolving this.
                    This PSU is not really so important, so I may just take the experience learnt and move on, if a replacement FET does nothing new.
                      Thanks.
                      Classic quote from the first page seems to sum up my situation perfectly
                      “The way to succeed is to double your failure rate.”
                      - Thomas J. Watson
                        Thanks.
                        - Thomas J. Watson
                        One of my teachers once quoted Thomas Edison on inventing something new. "It's 1% genius and 99% persistence."
                        Edison tried thousands of experiments to come up with the light bulb. He categorized everything he did. One of those things was the foundation for a vacuum tube.
                        My teacher was one of the people who made the first transistor computer that Westinghouse paid $2 million to develop.
