Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    dump needed for toshiba lcd tv
    model - 32PA200ze
    board - PE1006-1 V28A001322A1
    panel - LTA320AP05
    eeprom - 25Q80
      new dumps
        Hi Rajnhl
        I already used this files and screen is upside down
        my hardware is
        ves480unds-2d-n01
        17mb82s
        17ips71
        Thanks.
          try this file
          try to open service menu
            Hi Rajnhl
            all working perfect
            tank you very much
              Hi All
              Does anyone have the dump for a COBY TFTV4028
              Main Board---002-FV40-2812-00R
              Panel---T400HW03 V.2
                Looking for eprom samsung UN55D6005.
                  Je cherche eeprom de tv jvc "lt-32n310d tp.sis231.p83 aide moi et mercie
                    Dump ou eprome de tv jvc lt-32n310d
                      Thank you perfect
                      Electronicman
                        Sir i have electa eled-3229(t2-m) i need frimeware any one have plsssss
                          I need either USB update file or firmware dump for
                          Toshiba 48L3448DG
                          Board 17MB95M
                          Panel VES480UNVS-M01
                          Power 17IPS20
                          If anyone can help, thank you.
                            Originally posted by mariorocco
                            Si,grazie ma danno solo l'aggiornamento per usb,a me serve il file per caricare la flash.
                            Can't understand your language.pls. post in English.
                              What I guise you need file for USB.You can unzip this exe file.or double click it ,flash file will be created in pen drive
                                I can't figure out how to turn the file into .bin to load the flash
                                  Run exe file.it will create necessary file(s) on USB drive.after creating USB drive remove it safely from PC ,put it in led TV USB socket and power it.
                                    You're wrong. He needs the dump file and it must be loaded on the chip using a programmer
                                      Originally posted by pocketwatch62 View Post
                                      Does anyone have a dump for
                                      Sceptre
                                      Model----X322BV-HD*CK12BW2
                                      Main Board---T.RSC8.10B 12305
                                      A12081963
                                      T315CK12-BW2
                                      Panel----DTW0315CK12-A
                                      Tengo el dump para ese modelo de TV se copio de una tv funcionando al 100%:sonreĆ­r:
                                        Thanks Compuvision
                                          Compuvision,
                                          Do you have a
