Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    main 17MB211S and VES315WNDS-2D-N21
    Plese
    Te Rog
      Originally posted by dani502017 View Post
      I honestly do not have the time to edit hundreds of archives, who needs the software to write to me what she needs, danirestaurari@yahoo.com my mail. Most of the software is for tv 2010-2018
      When I have time, I will also climb the forum.
      All good to everyone.
      Please
        Philips 65PFL8708S/12 - Chassis QFU1.2E LA
        Current main software: QF2EU-0.173.67.0_bld5a
        Standby software: STDBY_77.4.8.16
        Attached working dumps:
        7CT3 M25P10-AV@SOIC8: SPI Flash with Standby Processor software and NVM
        7JA2 M24C64-W@TSSOP8: I2C EEPROM with NVM
        7HA0 Sil9287BCNU: EDID-data
        Note; EDID can only be read through HDMI, if you try to write EDID through HDMI it will not persist in the memory.
        You have to hook into the I2C-pins to successfully write the EDID.
        I have the NAND too, but it's too big to post here.
          Have to say this thread was totally useless to me, for others that also find it useless (probably quite a lot of u) you will just need to bite the bullet and buy a new motherboard
            agreed
              good day for all I need to see who does me the favor of passing me the dump for a tv apex model LE4643T with panel number V460HJ1-PE1. thank you and blessings for all
                Originally posted by dick_barton View Post
                Samsung LE40B530P7WXX
                Panel Number: LTF400HA08
                Mainboard: Saturn_DTV_Rev, Model: BN41-01165B
                Power Supply: H40F1_9HS, BN44-00264C Rev 1.4
                EEPROM: IC3001, ATMLH924, (ATMEL AT24C512B substitute)
                Perfect! Thank U!
                  HELLO FRIENDS I need dell moniter model no. SE2216H DUMP
                    Hello All,
                    Do you have a
                    dump for a COBY TFTV4028
                    Main Board---002-FV40-2812-00R
                    Panel---T400HW03 V.2
                      Hi All,
                      Does anyone have a dump for a vizio?
                      Model E390-A1
                      mainboard----715G5560-M01-000-004K----TXCCB02K042
                      PANEL---TPT390J1-HVN01 REV:000A
                        Hi everyone. I am searching for a working dump for a Finlux 32flhyr274 tv, with vestel ves315wnda-2d-n11 screen, 17MB82S MB and 17IPS62 power supply.
                        I tryied at least 10 dumps but if it starts, and the image isn't rotated the image quality is bad, and the remote isn't working very well.
                        other codes are also at each sticker,
                        backplate: 10106321 1611 601841
                        sn: 7694659 601841
                        screen: ves315wnda-2d-n11
                        23335377
                        VEL_LCM VES315WNDA2DN11_15_32261WCLWOR&S
                        tuner: 10106321 23335403 2186 32"
                        27696409 DIJ
                        1129
                        23239021 96409
                        V1129 LN4 ST
                        05*11 - 20/8-141
                        Hope somebody can help me with the good working dumps
                          Good afternoon,
                          I hope i write in correct section.
                          My blaupunkt tv turn on but no image on the sreen
                          So i think i can be a firmware bug!
                          i'm wondering if it exists a way to re upload the firmware using usb port by using a specif key press in tv buttons or using remote control ?
                          Many thanks to anyone that can explain me how to do if it is possible.
                          When it's not possible to make any add-on (cable, connector, etc.) that makes it possible to upload frimware. I think the new product are also somehow upload at the factory.
                          Firmware for this TV:
                          main board is t.msd309.btu87 (4k tv)
                          and panel display innolux V400DK1
                          I attached some picture about my tv.
                          Thank you for your help.
                            Hi everyone.
                            I am searching working dump spi flash for led tv 32".
                            main: LD.M3393.E
                            add unit: LF.M30.A1 1305
                            FHD panel: LTA320HJ03
                            Thanks in any case
                              sn: 7694659 601841
                              23335377
                              27696409 DIJ
                              1129
                              23239021 96409
                              V1129 LN4 ST
                              05*11 - 20/8-141
                              If you have saved the original bins, write to and try with this usb repair software
                                Hi everyone.
                                I am searching working dump spi flash 25Q32.
                                TV: MEDION
                                model: MD30479 DE-W
                                main: T.MSD309.8B 10304
                                panel: LTI320AP01
                                Thank you!
                                  Salve TV Diunamai wd-tv6600
                                  Main board : T.sp7050.9b 9502
                                  Power : ipb322s2
                                  pannello P190MWW3
                                  tuner CDT-SFT338-40
                                  U11 =25L80
                                  U9 =24c02
                                  U10 =24c02
                                    Sharp LC-32CHG6201K
                                    Sharp LC-32CHG6201K
                                    Blue screen, no pic & menue, will not turn off.
                                    Format usb stick FAT32, copy files.
                                    Unplug TV, insert USB stick & power up. Update progress appears on screen and takes about 7 mins.
                                    When complete, the set switches OFF - WAIT 1 or 2mins. until LED flashes rapidly then unplug and remove usb stick, power back ON.
                                    The instructions said to wait 15-20mins (this should read 15-20seconds I reckon), it takes 15-20 seconds to 'boot' the TV. I had it in 'Burn-in mode' and simply had to unplug, press the 'wobble button' at the back while plugging back in. I now had a working TV.
                                    Note This set is made by Hisense a UMC clone.
                                      as a member of this top notch site which over the years has helped me out alot. i want to give back.. so ive uplloaded a shed load of files to one of my servers enjoy,! and if you require any new JVC tv firmware. i have lots more, please ask,. what software / firmware or files you are after you never know as a tech i might have it cheers ..
                                      PLEASE SAY THANKS,
                                      http://77.81.110.132/Firmware/As36dFeRcVgFdd7g23JkLbX/
                                      DONT MISSTREAT MY SERVER PLEASE.
                                        PLEASE SAY THANKS,
                                        Crikey I was surprised how many files you have on it.
                                        Thanks for uploading them It is appreciated as they can be hard to get hold of especially the more obscure TV brands like Logik etc.
                                        Be lucky
                                        Regards Anthony
                                          Thank you
