Hey everyone,
So I know I'm working on my GX620's in another thread, however we just got a used Optiplex 780 SFF C2D Quad that we're going to start using (and probably stressing) a good bit, so before we put it in to service, I figured I better have a look inside.
The motherboard has the following caps I've identified.
Big ones in the middle: 1800uf 6.3V 105°C FL [M] 05IIEY
Everywhere: 470uf 6.3V KY (M) 105°C
Sporadically scattered: 120uf 16V 105°C FM [M]
Between the ram: Rubycon 1000uf 6.3V A1023 105°C PET
Oddball in the bottom right, only 1 of these and it's the only one that has a marker stripe on top: 220uf 16V KY (I think, that's all I can make out)
There's a few polymers near the CPU but I didn't include those.
None of them appear bloated (I know that doesn't mean anything) and interestingly only that one in the bottom right has the marker stripe on top.
From what I know, the FL and FM are Panasonic's and those are pretty rock solid (?) The Rubycon's are usually good too I believe. That leaves the KY's that are everywhere and I believe those are UCC caps.
Would anyone recommend a preventive recap of any/all on the motherboard? It was pretty clean when we got it, the fan under the hard drive was moderately dirty and I cleaned that up.
The power supply however worries me. It's model AC235AS-00
It has a couple of Ltec's, but the majority are CapXon caps. None are swelled, but they sure slapped em in, lots slanted. PSU wasn't filthy, but I did blow it out. I see lots of complaints about CapXon caps.
Does the PSU need a preventive recap?
Thanks again in advance, always great advice and knowledge around here.
