A New Dell or Compaq?
    Have been checking the prices to build a low end PC and it is way more than a comparable Dell or Compaq. I realize that there are more options if do it myself but all I am looking for now is a reliable inexpensive PC.
    Recently saw a few reviews about how good the low end Compaq is. http://www.pcmag.com/article2/0,1895,1870262,00.asp
    Has anyone checked to see if the caps in the low end Dell and Compaq PCs are good? Also if some of these models are using multiple mobo vendors then it seems wise to try to get the best one.
    Would appreciate any suggestions concerning packaged PCs.
    If decide to go this way will check all the mobo caps. Am also wondering if it would be smart to open and check the Power Supply and monitor caps. Only prob I know is that some power supplies have labels so will void warrenty if open.
    Gene
    Re: A New Dell or Compaq?
    i think Dell will be very careful about caps after the nichicon fiasco.
      Do you think Compaq has also learned from the Bad Cap problem?
      Gene
        Go Dell. I have used Compaq computers before and they all suck.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
          Be a little more descriptive. I've had a lot of Compaqs and they seemed to be great. All the Dells I had were lemons: bad hard drive, cpu failure, board chipset failure. I've had 3 Dells, which I got free. The Compaqs still perform ok, and 2 are sitting as servers while one is a web browsing computer for my mom.
            Gene
            HP owns COMPAQ...
            HP is doing well, HP acknowledged the cap problem and stopped all shipments of mainboards with the Nichicons in question...
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
