820-2533 Macbook Pro - SYS_ONEWIRE: 0
    15 inch macbook pro charger bulb doesn't come on. Seems there is a problem with SMC. The measured voltages given below. What could be the issue and and how can I go ahead?
    PPBUS_G3H: 12.6
    PP3V42_G3H: 3.4
    SMC_BC_ACOK: 3.2
    PP1V2_S5_SMC_VDD
    SMC_RESERT_L: 3.3
    SYS_ONEWIRE: 0
    SMC_PM_G2_EN: 3.4
    PP5V_S3:0
    Re: 820-2533 Macbook Pro - SYS_ONEWIRE: 0
    SMC should be ok.
    Try another Magsafe and DC-in board.
    Check voltages on U6900 and U6901.
      SMC_BC_ACOK_VCC is 3.3V
      So U6901 is giving the proper output.
      U6900 getting the 3.3V to VCC pin. R6929 is not open.
      Magsafe is woking fine with another computer
        What about voltage on pins 4 and 5 of U6900?
        And resistance to ground on pin 4 and 5?
          U6900
          Pin4 = 0V
          pin5 = 0V
          Resistance to ground
          Pin4 = 123 Ohms
          Pin5 = 1.7 M Ohms
            Remove U6900 and check voltage and resistance to ground on pin 4 again.
              Pin 4 pad
              Voltage 3.4V
              resistance to ground 5.4 M Ohms
                Seems like U6900 was bad, replace with a new one (or from donor board).
                  Great support. Thank you!
                  So, even multimeter is not beeping, a resistance ~ 100 ohms via a chip to ground can be considered as a short to ground. Isn't it?
                    Yes, in fact continuity mode with beep will often be misleading. It really depends on the line you are measuring. On CPU VCore power rail you'd have like 6 ohms and it'd beep but that's normal. On a data line you often expect at least a kiloohm.
                      Valuable information. After replacing U6900, now green bulb works on charger. Fan is not working yet. Have to check now.
                        Now SYS_ONEWIRE: 2.8V
                        Green Light is ON
                        S3 rails are not active yet.
                          You have to trigger power button for this machine to turn on.
                            Tried to trigger by touching the ground to SMC_ONOFF_L. Fan doesn't move at all.
                              Some voltages may be useful:
                              PM_PWRBTN_L: 3.4V
                              SMC_ONOFF_L: 3.4V
                              PM_SLP_S4_L: 0V
                              When trigger SMC_ONOFF_L, PM_PWRBTN_L goes down and come up.
                                The charger I have used is a 15V one. So, once charger is changed, SYS_ONEWIRE gives 3.3V
                                Still no luck with FAN
                                  You must use a good 85W Magsafe.
                                    Yes. That is what I am using now.
                                    What can I check for missing PM_SLP_S4_L?
