Philips 50PUT6400/12 no backlight
    Re: Philips 50PUT6400/12 no backlight
    Best to replace them all
    or buy new strips
    Not worth the hassle just to do the bad ones..
      I totally agree with replacing them all.
        Replaced blown leds with some i had but seems not quite right.
        Replacements were supposed to be:
        3030 3v 1w
        Vf 3.05-3.65v (250mA)
        6000-6500K
        120-130lm
        but then chinese imports so who knows what they actually sent.
        Think the colour temp is wrong, could see the difference before re-fitting but just wanted to see how it would look with panel back on. Not actually that noticeable whilst colours on the screen, its when its a greyish or white screen.
        The black band across the top is of course where an led has gone out again, perhaps poor soldering, underated mA or just cheapo crud. Or could be another 'old' led gone out.
          Do you have picture of the bacside of the LED showing the solder pad pattern? You also need to find out if the big pad is Anode or Cathode.
          Small pad is anode +
          Large pad is cathode -
            LG Inotek LED has Large pad as Anode.
            Most Samsung LED backlights have Large pad as Cathode.
            Did you use cool white 7000K?
              cold white 6000-6500k, at least thats what they were advertised as.
                sounds like the ones i have previously tried to fit and noticed the color issue too,i have recently ordered these and will give them a try
                https://www.ebay.co.uk/itm/Backlight...72.m2749.l2649
                  that black band looks like tab driver is damaged
                    Funnily enough I ordered some of those earlier today, from a different supplier mind you and paid a slightly higher price for mine though, but will still have to wait around 4-6 wks delivery time.
                    Be interested to hear how they compare to your last attempt!
                      Definately due to led's fortunately.
                        Did you get a chance to try these ones?
                        Mine arrived today but look very similar to the ones I have already replaced so think I will have the same problem.
                        Of course, I won't know for sure until I actually swap them over and power it up once its all put back together, not sure I'm prepared to go that far just yet!7
                          no mine have not arrived as yet and i have not got a led set here now for repair just two ccfl backlit ones.
                            if you send this ebay seller a message im sure he will help you hes very helpful and a lot of us on here use his shop https://www.ebay.co.uk/usr/microtech...88.m1543.l2754
                            Update :
                            Thanks, just what was needed.
                            Highly recommended!
                            TV now working again.
                              Hi
                              I think I may have the same issues but I'm only reading 60 volts on the +VLED and 0 on the -VLED. Do you still think it is an LED that is blown?
                                I have almost same problem but with 49pus6561/12.
                                Sound works, ambient lighting works, with flashlight I see picture.
                                So its backlight issue.
                                I measured +VLED to chasis GND and its 57v
                                When measuring -VLED to +VLED I see voltage between 8v - 60v. the voltage goes light up, down up down up down.
                                Even when backlight connector is removed. I also hear something clicking but cannot find or feel what it is.
                                Is this job for new PSU?
