pls Bios HP Probook 450 G5
    Hp 450 g5 bios
    hi everyone my laptop hp 450 g5 (DA0X8CMB6E0) not display and capslock bliking 5 times ..The laptop is water damage i clean board but now caps lock bliking 5 times and light power stay amber Fan spining fast and cpu not geting hot.... THIS IS OLD BIOS
      Re: Hp 450 g5 bios
      try..
        Re: pls Bios HP Probook 450 G5
        Have just fixed and hp 450 g5 which had no power and i cleaned out a mosfet which had a short and now the unit is powering up . but now the pc has very slow bios response upto 3min to start booting windows (no post delay) posts display in 3 to 5 seconds but will hold at hp logo for 3min before starting to load windows for about another 30 seconds . once in windows there are no symptoms of any nature until next reboot.
        .i flashed bios with new Me file and no change .
        i tried to boot into windows and update bios and it rebooted and took 45min installing bios but once done same thing.
        entering the bios also takes 3min and navigating take more than a min to processes any key strokes.
        i have tested the same file on other 450 g5 pcs with no problem .
        i tried a different bios chip
          Probook 450 G5 BIOS Password
          Hello, could somebody please remove BIOS password from this dump? My original bios chip is completely damaged, I found this bios working, but it is locked. Also, did I need change SN and PN after that with DMI tool, or can it be altered in dump file?
          Thank you in advance
            Re: Probook 450 G5 BIOS Password
            try..
              Thank you very much. After writing all IDs and locking MPM working again
              You are true hero. Have a nice day
                Hi every one,
                I dont know if it will be possible to fix my problem,
                But unfortunatly i made some mistake trying to flash the bios of my DA0X8CMB6E0 rev e.
                Using for first time eeprom programmer, i didnt choose the right chip on the ch341a software, so at first when i did a backup of original bios in my computer, the bin file was only 64Kb cause of wrong selected chip
                When i realized it it was too late, i had already programmed another bios in the chip, so after some documentation i tryed to flash almost every bios that i found in this thread and google with flashrom, but, no one of them work correctly, only getting 5 blinks on caps lock, black screen, and fan goes high.
                i put in attachment the 64Kb bios that i save, if it may help ?
                If some one solved anything like this, any help would be appreciated.
                Thank you in advance for your answers
                  HP 450 G5 DA0X8CMB6E0 rev e
                  Hi every one,
                  Using for first time eeprom programmer, i didnt choose the right chip on the ch341a software, so at first when i did a backup of original bios in my computer, the bin file was only 64Kb instead of 16Mb cause of wrong selected chip
                  When i realized it it was too late, i had already programmed another bios in the chip, so after some documentation i tryed to flash almost every bios that i found in this forum and google with flashrom, but, no one of them work correctly, only getting 5 blinks on caps lock, black screen, and fan goes high.
                    Re: HP 450 G5 DA0X8CMB6E0 rev e
                    Originally posted by Zoublerh View Post
                    Hi every one,
                    try..
                      Hi Peste,
                      Thank's for your answer,
                      Unfortunately i got the same result with the bios you send, black screen, 5 blinks, fan go high.
                      I don't understand why any BIOS work,
                      i tried :
                      - 11.8.50.3425_CON_LP_C_NPDM_PRD_RGN_outimage.bin
                      - 11.8.50.3425_outimage.bin
                      - 11.8.50.3470_CON_LP_C_outimage.bin
                      - DA0X8CMB6E0 REV E OK.bin
                      - HP ProBook 450 G5 _da0x8cmb6e0 reve 4MATIC.bin
                      - HP ProBook 450 G5 DA0X8CMB6E0 REV-E BIOS X8C.bin
                      - Orig+Q85_011101+11.8.50.3425_CON_LP_C_NPDM_PRD_RGN_outimage.bin
                      - Orig+Q85_011200+outimage.bin
                      - Q85_010901
                      - W25Q128.BIN
                      - W25Q128BV@WSON8_20201110_110401 DUMP_11.7.0.3307_CON_LP_C_NPDM_PRD_RGN.bin
                      Is there any reference to some hardware ID or serial number in the bios content ?
                      I didnt find a way to get hp original factory bios in there website.
                      Anyway, thanks for your answer
                        try this...
                          Originally posted by dihcar84 View Post
                          try this...
                          Hi dihcar84,
                          Got the same result, black screen, fan go high,
                          when i try to boot i only let motherboard with ram, screen and power entry, i removed all other devices (battery, ssd, sd card reader wifi/bluetooth board, speakers, pad, fingerprint sensor) also i removed cmos battery
                          i swap ram
                          is there anything i do wrong ?
                          PS : dihcar84 my parents born in rabat, and got an house in Kenitra ^^
                            Rebuild bios bin HP 450 G5
                            would someone be very nice and help me rebuild the bios file to make sure it is ok?
                            The old owner changed the BIOS on his own and now the laptop does not start.
                            MB: DA0X8CMB6E0 REV:E with integrated nvidia graphs
                            Old BIOS bin in attachment.
                            Thanks good peoples
                              Re: Rebuild bios bin HP 450 G5
                              Thanks good peoples
                              try..
                                Re: hp 450 g3 unlock
                                Pls help me unlock the password on this bin file
                                  Re: HP probook 450 G5 bios password
                                  Hi. Need help to reset bios pass on my ProBook G5
                                    try .. if it works write the DMI information
                                      https://www.badcaps.net/forum/member.php?u=201805
                                      please check
                                        hp probook 450 g5 5 blinks on caps
                                        hello if some1 can help me i have hp probook 450 g5 org bios dump no start nothing i replaced bios from another board and now its starts but 5 blinks on caps and num but after a few seconds it will boot to windows and all is normal I attached both dumps if someone could help me
                                          Re: hp probook 450 g5 5 blinks on caps
                                          try..
