OK, so done a test
D10/D11 = 550
D8/D9 = 895
D13/D14 = 375 using a EEDM501B multi meter on the 2K ACV setting
Can you explain how you test the Diode on the 2K ACV setting?
What setting of the meter did you use to test D8/9/10/11?
Are you testing the diode with TV still plugged into the AC outlet?
I have a Haier 50" LE50d3505b television that is "dead." No image, no standby lights, no sound, no nothing. The power supply board is HKL-500201A.
I have tested diodes 10/11 using the "diode setting" on my multi-meter. I got .000 readings for both. For diodes 13/14, I got .177 for both readings.
Do you think diodes 10/11 are the issue and to replace them? If so....would these be the correct diodes to replace them with: https://www.ebay.com/itm/11376729897...QAAOSwDw9bLDvU
