Identify diode
    Identify diode
    Hello guys,
    I have an element that is most probably a diode or Schottky barrier.
    Can you recognise this and suggest me an alternative element to use. This element is on the 12V power line in monitor.
    Thank you.
    Re: Identify diode
    Looks like Schottky diode. But I cant recognize the marking.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
      Re: Identify diode
      The logo is not one of the classic companies, probably some random Asian one.
      Possibly it's an SMD version of the SB5100? (5A, 100v Schottky)
      Is it just in-line with the power supply for reverse protection?
      -David VanHorn
        Re: Identify diode
        This diode is in serial with input power supply.
        I found this: https://id.aliexpress.com/item/1005002238622939.html
        I still need to figure out whether this 322C has special meaning. Input power is 12V, so 100V schottky seems too large.
          Re: Identify diode
          322C is probably the date code given that 5100B matches a diode that does exist, and one of those SB5100s would make sense given its use in circuit.
          100v is just the maximum reverse voltage, it won't hurt anything in that it's higher than 12v. It probably doesn't *need* to be that high but it won't matter if it is.
          Now I ask the question, what is the real problem with the monitor?
          -David VanHorn
            Re: Identify diode
            So, it corresponds to barrel type 5A shottky diode, just this one is chineese and smd.
            I found the datasheet for 5A barrel type 5100-b, but was not sure whether the smd corresponds, or its just random chineese marking
              Re: Identify diode
              Don't really know, no signs of life. Monitor is HP 23xi. Found this diode open circuit in series with 12V power input. Put regular diode to test further and after that this diode and the transistor behind it started to getting very hot. On the transistor is written APM1110N Q0706. It is most likely short circuit somewhere on the board. It is evident on the PCB that a lot of heat dissipated here.
                Re: Identify diode
                schottky needs to be a good 10x the running voltage,
                they are very easy to destroy with spikes.
                  Re: Identify diode
                  I found the same board that has a BSCD510 in that same location. 100v 5amp Schottky Barrier Diode
                  Are you using diode test or just regular resistance scale on your meter to check it?
                  You might be able to replace the whole board for less money than repairing it.
                    Re: Identify diode
                    Even if not used as a rectifier?
                    -David VanHorn
                      Re: Identify diode
                      Looks like the switching MOSFET for the LED backlight driver. Driven from pin 26 of that EUP2589. Pretty weird though that the silkscreen for that MOSFET reads the pin labels like a linear regulator!
                      Anyway, the EUP2589 claims to have short circuit protection so perhaps either the MOSFET failed or the controller is bad.
                      -David VanHorn
                        Re: Identify diode
                        The diode seems to be is used in the boost circuit for the backlights, so it will be a higher voltage.
                          Re: Identify diode
                          Thank you guys, I have replaced the whole board, it was easier and cheaper. So, the original problem is solved.
                          I was curious about this diode because I didn't know what is exactly. Anyway, I have learned something new.
                          Thank you again.
