Hello. I'm currently working on a Lenovo Ideapad 330S-15IKB that has no power, no power light, dead. I found the schematics and I'm seeing proper voltage at the drain of the first DC IN MOSFET and nothing after. After doing some research and finding the power supply troubleshooting guide in this forum. I tested the second DC IN MOSFET and it's shorted from drain to source. My main question is since I'm new to doing this, I thought I heard somewhere that any time a MOSFET goes, you're supposed to replace the controller as well. That may not be right but I want to check if there's anything else I would need to replace with it. I don't want to just replace the MOSFET only for it to blow again. I can upload the schematics I'm using if I need to, or if there's other info you need let me know.
330S-15IKB Components to replace along with shorted power MOSFET
Re: Components to replace along with shorted power MOSFET
^^ +1 on that. Most designs 2012 or later use very high value resistors on the gates of the mosfets in the DC-in circuit so unless there is liquid damage, the charging IC will be fine 95% of the time and replacing the shorted mosfet is the only repair required.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
Originally posted by Th3_uN1Qu3 View Post^^ +1 on that. Most designs 2012 or later use very high value resistors on the gates of the mosfets in the DC-in circuit so unless there is liquid damage, the charging IC will be fine 95% of the time and replacing the shorted mosfet is the only repair required.
When the mosfet goes completely short, it usually takes out the gate driver as well if IT is coupled directly or via a low value resistor (less than 50 ohms). Most dc/dc converters use no or very low gate resistors because they need to switch the mosfets very fast. The DC-in circuit only needs the mosfets as on/off switches, therefore it doesn't particularly care how fast they act, hence the use of large value resistors on the gates.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
Originally posted by Th3_uN1Qu3 View PostWhen the mosfet goes completely short, it usually takes out the gate driver as well if IT is coupled directly or via a low value resistor (less than 50 ohms). Most dc/dc converters use no or very low gate resistors because they need to switch the mosfets very fast. The DC-in circuit only needs the mosfets as on/off switches, therefore it doesn't particularly care how fast they act, hence the use of large value resistors on the gates.
Great explanation! Thanks
