XVDV55 Pioneer , no disc play
    Hi all
    Seems that the CD reader had failed .
    Could only find it listed on Ebay via Liberty Electronics .
    Have bought from them before & been quite reliable .
    Quite an expensive part & wondering if there are any other suppliers in UK , or Europe so that i can save on post .
    https://www.ebay.co.uk/itm/282281869568
    Re: XVDV55 Pioneer , no disc play
    CD reader arrived , but thought before i fit ,will check caps on the servo board .
    Replaced several with poor readings .
    Now for the reader .
      Reader fitted & on test with a music CD
        A few other issues with this unit .
        On occasion when tray ejected , it would retracted by itself .
        Pulled tray out to access the detect switch , & cleaned with IPA
        Also the FRONT speaker audio would cut out intermittently .
        Discovered the top 2 speaker protect relays corresponding to FRONT were dry jointed at the coil side .
          Remote control not working either .
          Once stripped down issue was self evident .
          Glue once used to secure the 8MHZ oscillator had become corrosive .
          A replacement restored operation .
            Play back was still a touch temperamental .
            To resolve this removed turntable motor & sprayed some IPA through the underside onto brushes .
              Yet again from a cold start , after being off for a day , it wouldn't play .
              Took a hair drier to the PSU module , then sprang into life again .
              Time for more cap replacements i think .
                One cap found with a very poor ESR reading , C5012 ( 10MF , 50V )
                Hopefully this is the cause .
                  Powered , tested from cold start on two consecutive mornings & all good so far .
