Re: MSI RX6900XT - i fcked up - shorted TOUT with BOOT on
god bless AMD for fusing everything. i find that my short blown one of OptiMOS and 20A fuse. after MANY usoldered/soldered capacitors and coils and three hours of work my mistake is repaired.
But this OptiMOS i cannot find to buy. I have this AON5470 with same layout from RX6800. Have anybody datasheet for it to check if have enought current to use it?
I soldered a wire onto the bottom side PCB, to get at the enable pin of a DRMOS, and now the resistance of the pin reads way more, even with the wire removed again. I don't get how I damaged anything.
I barely touch these when powered, I'd fry too much stuff.
The 5470qe is probably a custom chip, no datasheet/public offer available, only solution is buy another broken card and use it as donor. You can try to write to Alpha&Omega, but wouldn't expect a helpful response. Remember that MOS devices can change and hold some time state during measuring from non-conducting to conducting and vice versa only due to the applied measuring voltage (gate must be included, state depends on polarity applied to gate), so sometimes it's possible to measure completely different values, and this must not mean, that the device is broken.
