Hello All,
Picked this up at a recycle center with hopes of a simple fix.
When plugged in, the backlights come on, two blue LEDs on the T-con board illuminate then one goes out. Cycling the on-off switch has no effect.
On the power supply board there are four test points labeled +, sine wave, sine wave and -. There is 120VAC across the sine waves and 113VDC across
+ and -. All the caps look good.
I'm not sure where to check for the standby voltage output?
Shop Jimmy's has plenty of PS boards, Main boards and T-con boards. All three would cost about $70, but if possible I'd like to narrow down any potential fix.
Any feedback is much appreciated. Thanks!!
