Laptop Asus ROG GX531GM dead
    On my work (hobby) bench, I have a Asus ROG Zephyrus S GX531GM (gaming laptop), it's completely dead.
    Removed the motherboard and I did find only the 19V rails on several points on the motherboard.
    There is no voltage on the power button and the 25L12873F (bios chip) has also no voltage (pin 4 + 8).
    The bios battery had no voltage any more, I have replaced this battery but no difference. A hard reset after removing the bios battery and external power (pressing the power button for 40 seconds also no difference).
    Information from the motherboard is GX531GM Main Board Rev. 1.3
    Searched for shorts on mosfets, did not find any. But all the caps i have measured (also the black ones) are shorted (see image which part of the board).
    This is a full size picture of the board:
    This is the part with the shorts:
    Some one who has an idea. Did not find any schematics, so no clue where the voltages are generated (5v, 3.3v, 1.8v, etc..).
    Re: Laptop Asus ROG GX531GM dead
    hi. not aware of schematics for Asus anything. They appear to be locking away their secrets @ Fort Knox.
    With a meter on resistance mode, check the resistance of each coil to ground.
    Do you see any super low readings ?
    Based on your post, one or more caps are shorted which is likely leading to a high current event and shutting down the local regulator.
    You can trace the DCIN and see if there is a local SMD fuse (often white in color).
    Can you zoom in where you apply the external adapter and share quality pictures?
      https://www.badcaps.net/forum/showpo...02&postcount=2
      2.2. Don't suspect that something is shorted with no reason
      Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
        I have done the measuerments of these coils:
        https://freeimage.host/i/BolafV
        Coils from left to right
        1,2,3,4,5,6: 00.8 ohm (setting on 200ohm)
        7,8,9,10: 00,5 ohm (setting on 200ohm)
        11: 7,4 ohm (setting on 200ohm)
        There are also mosfets on the back of the board. I measure shorts on all of them, between the Drain and Source.
        https://freeimage.host/i/BolGOg
        Modelnumber of those mosfet 4C06B > https://datasheetspdf.com/pdf-file/7...r/NTMFS4C06N/1)
        The vias from the 4C06B mosfets, are connected on the other side of the board to the coils (underneath the coils, I think top pad of the coils).
        The mosfets on top of the board, are the 4C09B, they don't have a short between the Drain and Source (or gate) > https://datasheetspdf.com/pdf-file/8...r/NTMFS4C09N/1
        Regarding a fuse on the board > DCIN, did not find any abvious fuses (non of the parts have any markings on the board, like F1).
        This is the part where the DCIN connector is.
        https://freeimage.host/i/BolWzJ (underside of the board)
        https://freeimage.host/i/BolXWv (underside of the board > topside is the current resistor).
        https://freeimage.host/i/BolhsR (topside of the board)
          These seems fine because they are gpu coils and that low ohm reading is ok.
          These are not good. 7,8,9,10 are cpu coils and should be somewhere around 2 ohms at least.
            Based on the advice from @myth77, check the coils 7,8,9,10 and locate which caps are mating with each coil. Guessing the 2-4 large black polarized tantalum caps are linked to at least one of these coils (marked with 470 and 220).
            Then with a hot air tool, consider to desolder one side of the cap so you can lift the cap to remove from this leg of the circuit. Then check the coil to ground resistance again. Does this remove the ultra low resistance value of 0,5 ohms?
            There will be a lot of ground plane in these regions of the PCB so proceed with caution and patience. Flux on the cap solder tabs will be help. You can also apply leaded solder (which is low temp as compared to ROHS) onto the same solder joints to assist.
            With this method, you can locate a possible bad cap. There is also a possibility of the CPU being bad but no direct experience with that topic...yet.
              My advice would be to remove those 7,8,9,10 coils with heatgun and then check what side is shorted to gnd...pray that it is the other side(opposite to cpu) because if it is CPU side shorted chances are 99% that cpu is dead. That 1% is maybe, but just maybe that some cpu cap dead... but that is very rare.
                I have lifted all the coils and those 4 caps, the side that's shorted to ground is above the CPU (not above those coils).
                All those small caps are also measuring a short, also those black "New e8N" (caps?).
                On the backside of the board, the short between the Drain and Source is gone now.
                https://freeimage.host/i/BojVaf
                  Someone who has an idea how to find the part that's causing the short to ground.
                  I have a lab power supply, it's the Delta Elektronika 030-5 (0-30V / 0-5A).
                    A co-worker of mine has loaned a FLIR thermal camera to me. After placing the power adapter and measuring with the FLIR thermal camera, there are now hotspots on the board.
                    Unfortunately, did not find the schematics for this board.
                    Anyone who has an idea?
                      0.5 Ohms is not abnormal on 8th gen or later cpu's-I dont think there is a short on cpu coil. Your problem may be elsewhere. Do the basics first. Check DC-in mosfets for voltage/shorting.Then check whether you have +19V rail on CLR. then proceed to check 3/5V LDO and then to kbc basic requirements. As # piernov has already said, all problems dont relate to short.
                        Are you sure? I think i measured two or three i7-8750h chips vccore resistence and on all working it was arround 2,3 ohm! Maybe someone else can confirm...
                          update....on this subject below post23, there is reading 2.1 ohm on cpu vcore
                          https://www.badcaps.net/forum/showth...t=8750h&page=2
                            I don't have a way to confirm, but 0.5 ohm on VCore sounds too low for mobile Coffee Lake, as far as I know all mobile Skylake and newer should measure more than a couple of ohms (maybe just a bit lower on the iGPU power rail), often around a few ohms. Of course it has to be measured when the board is dead cold, all power drained from it.
                              I had done some measurements, after the DC-in mosfets (and current limiting resistor) there is the correct voltage present.
                              Have done on several points (random picked) measurements, the 19V rail is present.
                              Did not find any schematics for this motherboard, and even when they are there, the boardview is also necessary.
                              There are no numbers printed on the board, with a reference to the schematic (PU200 as example).
                              My knowledge is to low for such a repair.
                              I life in the Netherlands, some one here who has the knowledge and in for a challenge
