Re: Fixing a laboratory DSC
lamps in parallel will allow more current.
lamps in series are pointless unless they are the wrong voltage.
i mentioned 2 in series because i thought you were going to do it with the 240v side and being canadian your lamps are 120v
and dont give it 6a or a fault could cause a fire.
if you disconnect the load from the power supplies then 1a should be more than enough to get them started.
which is unlikely because we are searching for a fault!
