Curious if anyone has seen this behavior or not, or could it be simply explained by a very obvious reason...
... is it common for a cpu at the same clock rate and voltage to get hotter (perhaps, draw more current) as it gets older?
The obvious reason... fan clogging up with dust or heatsink compound drying up, of course. Or perhaps it's possible for the heatsink to not be as effective as before, should heatsinks' fins be cleaned with more than just compressed air/vacuum? Perhaps dunked into a ultrasonic bath? Then perhaps the heatsink should be replaced (with like, since it had been working fine for many years prior)?
Having a weird situation, heatsink had been working just fine for many years but now, even after cleaning with an air compressor, is no longer providing enough cooling. Grr...
