HP 15-ba025nv, la-d711p rev 3.0, FULL FAN NO IMAGE, FIX BIOS
    Hello, can someone fix this bios
    with the other one i extracted from the hp website it works but no info
    Re: HP 15-ba025nv, la-d711p rev 3.0, FULL FAN NO IMAGE, FIX BIOS
    Copy the DMI from the offsets provided in the picture.Copy from the old and paste-inset into the new bios using the same offsets.
    HxD hex editor https://mh-nexus.de/en/hxd/
      Thank you i will try and post results
      do you know if there is a way to fix
      manufacture programming mode is in unlock mode
      from editing the bios file?
      so i don't have to run the hp program afterwards
        Yes just leave it,it will lock itself after 30 or so reboots.
          it worked for the info, but the 30 reboots did not work, i will do it with the hp program
          thanks
            hello friends, I hope you can help me, I have a good HP 15 ba021ca BDL51 LA-D711P R 3.0, it only turns on the charging led and when I turn it on, it turns on the power led for a few seconds, I already programmed the bios, maybe it is the EC chip, someone will have the files to program this chip?
              post the original laptop bios here.
                The attached bios works fine, I tested it.
                  This file already contains a filled DMI block (i.e. is copied from a working machine), the file in post #1 (working no info 082F6.rar) is virgin dump from HP, the DMI information should be copied from the old dump to the one at the first post.
                  I don't see any point in using any other file other than a virgin one from the manufacturer's site.
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                    1000000000000000000000000% working
                      100% working
                      very thanks
