Recapped most of the Capxons on a PS board, but monitor is still not working. Didn't replace two Rubycon 35v1000uf caps. Pulled them to test, I have one of those little component testers with the LCD screen. Multiple testing cycles put them at Vloss 0.5 - 0.8, capacitance at ~930, and ESR at 0.00 - 0.01 ohms. I also didn't replace the large main cap. It's 150uf450V, and tests at Vloss = 1.0%, C = 138.3uf, ESR= 0.46ohms. Should I replace these or is that acceptable and I should look elsewhere for the fault? The issue is intermittent, but not working far more than it is working.
One of the caps on the PS that was visibly bulging had a Vloss of 21%, so that one is obviously bad. These Rubycons that I didn't replace are right next to it on the board.
See this thread for a more detailed description, if you're curious.
