B+ Voltage rail; Lenovo Y510p VIQY1 NM-A032
    Re: B+ Voltage rail; Lenovo Y510p VIQY1 NM-A032
    What are the voltage readings of pin # 4 (gate) on:
    PQ301
    PQ302
    - check both with the adapter connected - no battery.
    Also check and post the readings @
    PQ301 - pins 1-2-3 (any of these pins is ok for the measurement)
      Both gates PQ301 and PQ302 are 19,5V.
      PQ301 input: 20V, output 19,5V;
      PQ302: input: 19,5V, output 0,8V.
        Waiting for any ideas :<
        My idea was to try maybe trace the PGood status of PU301, but im not sure where and what to look for...
          Both PQ301 & PQ302 are P-channel mosfets.
          With P-channel mosfets, the GATE must be lower than the voltage being passed between source & drain. If you are measuring 19v @ the gate pin # 4, then the mosfet should be OFF.
          PQ302 appears to be OFF and this is expected.
          PQ301 appears to be full ON - incorrect for P-channel.
          Confirm the voltages on PQ301 again - source; drain; gate.
          Was this part replaced and soldered on in the same orientation ?
          It appears to be leaking if source & drain are at the same voltage yet GATE = 19v.
          Check with removing all power. Wait a minute to allow for discharge of the caps.
          Meter in resistance mode - check the resistance across the pins like before:
          source (1-2-3) & drain (5-6-7-8)
          source (1-2-3) & gate (4)
          gate (4) & drain (5-6-7-8)
          Post the readings.
            Picture with voltage measurements in attachment.
            The second schematic screenshot shows the gate for PQ301. If I have 19,5V on gate there, then something attached to it should give 19,5V right? Either Green line, Yellow line, or from the mosfet itself (which shoudln't happen given the resistances from before right?)
              No. This is a P-channel mosfet so the gate has to be sufficiently negative or lower than the voltage INPUT to enable the mosfet.
              You have ~20 V as input and ~19v5 as the output with the gate @ 19v5 which is not low enough on the gate pin to turn on this mosfet.
              Do you have another P-channel mosfet you can use to replace PQ301 ?
                This is happening perhaps as first dc in fet is working in diode mode due to improper biasing of gate voltage. The mosfet itself is unlikely to be bad.
                  So, what do You suggest mcplslg123 ?
                    Shouldnt PQ303 be bringing the PQ301 gate voltage down and to do that PQ304 should be switched on.The PQ301 gate voltage should be at least 5V lower ?
                      I've removed the PQ303 and measured its resistance:
                      Pin 1 - IN; 2 -GND; 3-OUT
                      1-2 95 KOhms no matter the polarisation
                      1-3 6,75 MOhms with red on 1; no reading opposite
                      2-3 6,75 MOhms with red on 2; no reasing opposite
                      In diode mode: no reading no matter which pin and which polarisation.
                      Quick google for schematic and added it in attachement.
                        Remove both PQ303 & PQ304 and power up. Check Readings on PQ301/PQ302 again. It wont harm you to apply power without PQ303/304 as they are just protection circuit.
                          After desoldering PQ303 and PQ304, small difference in voltage at the gates - 19,18V not 19,5V - screenshot in attachment.
                          So do You think the culprit could be the PU301?
                            Post the measurements for points # 1 & # 2 of the attached.
                              1: PQ305 pin 2 and 5 (the same): 0V; resistance to ground 10,9 kOhms
                              2: PR305 2nd leg: 0V; resistance to ground 57,3 kOhms
                                Have you replaced BQ24737 so far?? Yes it could be faulty but there can be so many reasons. Is PQ310 not broken??PACIN is missing and this is needed to trigger voltage divider for PQ301 gate. When PQ305B,pin5 will be high, GND will reach pin3 and then PR302/304 will work as voltage divider. Since GND is missing on PR304,pin2 its not working as voltage divider. So search all traces related to PACIN and check them. BQ24737,ACOK aka ACPRN will be active low. Do you get 19V on pin20 and 6V on pin16 of PU301??
                                    No, not yet. I could order it new, and try to replace it, but I would like to learn, how to know if its broken:-)
                                    PQ310 Voltages:
                                    pins 1-3: 0,8V (its the same voltage as PQ302 output)
                                    pin 4: 3,5V
                                    pins 5-8: 1,2V
                                    No shorts
                                    PU301 pin 20: 19,5V
                                    PU301 pin 16: 6V
                                    So yes, those are the voltages present.
                                      PR305, pin #1 was requested.
                                        1st leg is the same as PQ305 pin 2 and 5.
                                        Or i changed them up, so 1 is 2 and 2 is 1 sorry
                                          So should I order and replace PU301 (BQ24737), or desolder it and try to measure on the board if its for sure its fault and nothing else?
