12" Macbook 820-00045 PM_SLP_S5_L Is Missing
  • Comp_Pro
    • Jun 2020
    • 33
    Hello all,
    I was supposed to only be replacing the LCD on this macbook but it ended up becoming a head ache. Original issue was bad display, after installing new display we found there was no video, but it did make the charge sound. Never heard the boot up sound however. After this I noticed some liquid around the edges of the board but I did not find any corrosion anywhere.
    I ultrasonic cleaned the board and now I have no power at all, the charge sound has gone away. My ammeter says 20V 0A. I have all voltages up to S4 rails.
    ppbus_g3h 8.63v
    pp3v3_g3h 3.27v
    pp3v3r3v0_aon 3.26v
    ppvrtc_g3h 3.3v
    pp5v_g3h_ldo 4.57v
    pp3v3_s5 3.3v
    pp5v1_s4sw 0v
    PP5V_S4 0V
    PP3V_S4 0V
    After this everything is zero.
    I noticed PM_SLP_S5_L is missing and thus S4 rails are not being turned on.
    What might be causing this issue? Thank you in advance for your help guys!
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: 12" Macbook 820-00045 PM_SLP_S5_L Is Missing
    You need to check all the PCH power supplies in the S3 and S5 states. For example: PP1V05_S5_PCH_VCCDSW, PP1V2_S3, PP3V3_SUS, PP1V05_SUS_PCH_VCCAOSCSUS.
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • computeka
      Macbook Air A2337 820-02016-07 No sound problem
      by computeka
      How about everyone, I have a MacBook Air which did not turn on, it had a lot of corrosion on the card where the sound plug and the fingerprint go, I have replaced it and the device now turns on but has no sound, if I connect a headphone through the plug, yes There is sound but the external speakers do not sound....
      05-08-2024, 10:26 AM
    • edugimeno
      Help me identify the missing component... Sound to light circuit
      by edugimeno
      hI there!
      Im trying to help a friend repairing a large, real-sized short-circuit robot.
      This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
      Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
      What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
      So I bought a simple 2X30W amplifier to feed the loudspeaker...
      02-14-2024, 10:23 AM
    • Adogabriel100
      Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
      by Adogabriel100
      Hey! This is a A1278 macbook 2011.
      Problem: Not turning on / No green light
      Im using by3200s charger.
      Voltajes:
      PPBUS_G3H = 12.26v
      SMC_RESET_L = 3.3v
      PP3V42_G3H = 3.42v
      U7000 =
      Pin 1 CHGR_AGATE = 0v
      Pin 2 CHRG_DCIN = 19v
      Pin 3 CHRG_ACIN = 4.6v
      Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
      Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
      Pin 12 PP3V42_G3H = 3.42v
      Pin 13 CHRG_RST_L = 3.3V
      Pin 14 SMC_BC_ACOK = 0.8V
      Pin 19 PP5V1_CHRG_VDD = 5.05V
      Pin 20 PP5V1_CHRG_VDDP = 5.03V...
      04-01-2024, 01:02 PM
    • Comp_Pro
      Macbook Air 820-00165 Static Chime Sound
      by Comp_Pro
      Hello all,
      I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
      11-02-2023, 03:23 PM
