Lenovo Z500 LA-9063P noBacklight - No PWM voltage
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3570
    • slovakia
    Hello.
    Have this Lenovo Z500 LA-9063P that have no Backlight. All voltages is ok but no PWM voltage. R431 have no voltage on botha sides. looks like PWM come right from EC. This means that EC is burned?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3570
    • slovakia
    Re: Lenovo Z500 LA-9063P noBacklight - No PWM voltage
    what a damn solution. enter bios and push button for add baklight and all work
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3570
      • slovakia
      system offcourse need that mighty registry change to have working backlight buttons on Z500
      • salmec
        • Jan 2025
        • Italia
        I have the same issue but entering the BIOS I cannot find any button to add back light..
        Suddenly my Backlight power off and now I'm using an external display, sometimes on external monitor I can see some flickering or illumination changes...
        By original keybard pressing F11 or F12 UI can see the illumination bar active, but nothing is changing. Max illumination = Zero illumination.
        Thanks in advance
        Salmec
        • erico
          Lenovo X1 Carbon BIOS not getting voltage
          by erico
          First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
          I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
          So far these are my diagnostics:
          When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
          When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
          If i plug the battery...
          05-02-2024, 02:40 AM
        • jaroslav.psenicka
          Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
          by jaroslav.psenicka
          I have a Lenovo Yoga 13 Panasonic here, when powered
          • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
          • most voltage rails seem OK (see image below, red labels)
          • resistnace to ground mostly seem OK as well (blue labels)
          the only suspicious is the 0.0V rail (2nd from left, top row)
          • the resistance to ground is rather low (1.9ohm)
          • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
          also tried new BIOS, no change
          I can't find a schematics for the board - can some of you gurus look at the voltages?...
          05-02-2024, 05:59 AM
        • wrobbie
          Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
          by wrobbie
          My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
          02-26-2025, 10:02 PM
          Lenovo IdeaPad Z500 Laptop Schematic
          LA-9061P...
          10-08-2024, 11:40 AM
          Lenovo 3000 Series Schematic
          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
          3000 C100 laptop with Braille keyboard
          Lenovo 3000 C
          C100, C200 - 15-inch XGA screen
          Lenovo 3000 N
          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
          N500 - 15.4 inch screen.
          Lenovo 3000 V
          V100, V200 - 12.1-inch WXGA models
          Lenovo 3000 G
          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
          10-04-2024, 06:05 AM
