VSX-1021-k MCACC flashing
    Re: VSX-1021-k MCACC flashing
    I finally had time to look into this, and Redwire you were correct Q484 was bad. when I swapped with the channel next to it the problem moved to the other channel. afterwards I check the other bad channel and the same transistor was bad also. thank-you Redwire and Budwich for your support.
      great work.
