Mosfet Tester - Good Design?
    Re: Mosfet Tester - Good Design?
    Most MOSFET had D-S reverse breakdown voltage of 30V or more, so 9V is not going to do any damage.
    I don't have a MOSFET databook, but based on an online GlobalSpec MOSFET datasheet parameter search, the least breakdown voltage is 12V, so you're probably right. I found one with 9V breakdown voltage elsewhere, but it's an SMD.
      I have seen an 8Vds P-FET, with a gate-source voltage limit of +/-8V as well... it was SMD.
        The diode is part of the MOSFET. I understand it's possible to make a MOSFET without it -- but it tends to latch up far too much, so it isn't used in practice.
          The word "intrinsic" say it all. It's just not possible to build a Mosfet without the intrinsic parasitic Drain Source Diode.
          See some references:
          http://irf.custhelp.com/app/answers/...ng-psu-outputs.
          https://cdn.badcaps-static.com/pdfs/...3b1facbbe8.pdf
