Lenovo thinkpad t570 bios password
    Need help
    cant get access to the setup (locked by password)
    where is the password stored? IS IT IN THIS BIN OR SOME WHERE ELSE ON THE MOTHERBOARD?
    Re: Lenovo thinkpad t570 bios password
    please try it
      Originally posted by tdelfy View Post
      please try it
      thanks for ur help, but not working
        try this given bios write the bios and check if you will not get any beep sound than you are good to go for below given steps
        Step 0: Unlock all batteries, even the CMOS small battery
        STEP 1: Flash Given PATCHED Bios
        STEP 2: Boot the machine
        STEP 3: Press ENTER/F1/ to enter BIOS settings
        STEP 4: Enter 1234 when asked for Supervisor Password
        STEP 5: Press enter when it shows Hardware ID
        STEP 6: Press space bar 2x when asked
        STEP 7: Turn off machine
        {Now 1st part is complete }
        STEP 8: now You Have To Remove the bios chip & write your old original backup bios (lenovo t570 origi.BIN) and plug back in the CMOS battery.
        STEP 9:Start Laptop Go to bios setting by pressing F1 & Reset BIOS settings to factory default save and exit
          thanks , i will be right back to you
            Re: Lenovo Thinkpad T570 BIOS
            i have t570 the bios password is unknown can you patch/unlock the bios please, I will be really grateful.
            Regards
              Regards
              STEP 1: Flash and replace current BIOS with the generated patch file
              STEP 3: Press ENTER/F1/etc. to enter BIOS settings
              STEP 4: Enter any character when asked for Supervisor Password
              STEP 8: Restore original BIOS
              STEP 9: Reset BIOS settings to factory defaulT
                Thanks for the patch I managed to perform the above process but the laptop is still stuck on ''ENTERING SETUP'' .
                restarted a few times, discharged the cmos but no joy.
                  hi,
                  thanks for the patch i managed to perform the above process but the laptop is still stuck on ''entering setup'' .
                  Restarted a few times, discharged the cmos but no joy.
                  power off laptop
                  then re power on laptop
                  press f1
                  its require password
                  then enter 1234
                    Yes,
                    i restarted a few times, just stuck on Entering Setup, not asking for a password yet, its been over 20 mins
                      Lenovo T570 20JX-S0Y400 Bios
                      My friend gave me a T570 which has a supervisor password. I've been searching ways all over the internet and finally decided to go with patching the Bios.
                      I've managed to get a dump of the current Bios (hopefully I did it right). I would be glad if anyone could help me with finding an unlocked Bios for this laptop.
                      Thank you very much in advance.
                      PS: I've found several patched Bios files for T570 from this forum but I couldn't manage to get them working.
                      With one of the dumps, I got into setup and could change a few things but most of the things were greyed out and were not changeable (patch from this thread: https://www.badcaps.net/forum/showth...highlight=t570).
                      With the other one, I had no luck at all (black screen, power light on but nothing else). Patch from this thread: https://www.badcaps.net/forum/showthread.php?p=1023238
                        Re: Lenovo T570 20JX-S0Y400 Bios
                        Hello again, any help would be much appreciated.
                        Thanks.
                          Hi, need help with bios password.
                            I read this forum, the question was solved
                              Lenovo T570 20HA-S0C500 bios password
                              Hi !
                              Could anyone help please remove my bios password?
                                Re: Lenovo T570 20HA-S0C500 bios password
                                Originally posted by neospider View Post
                                Hi !
                                You MUST:
                                Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                                  Hello friend, please i need unlock T570 bios password
                                  my dump
                                  thanks
                                    Regards
                                      guys how to patch bios? is that patch bios same for every model of t570, or u must patch original bios?
                                        ok. i remenber i use lenovo autopatcher
