Zotac mainboard needs PSU with 8-pin mobo connector
  • binsonk
    • Apr 2014
    • 182
    For my Zotac GeForce 9300 mainboard, I need a PSU with an 8-pin motherboard connector. This PSU is hard to find and expensive. An adapter is available to combine with a 4-pin mobo connector to make it an 8-pin. Does anyone have experience with these $5 adapters, or would it be better to buy a PSU with the 8-pin mobo connector?
  • Compgeke
    • Feb 2014
    • 524
    Re: Zotac mainboard needs PSU with 8-pin mobo connector
    For the most part you can just plug the 4-pin into the 8 and it'll work fine, just don't expect overclocking and such to be stable. I've never known a board that won't work using a 4 in the 8.
    • binsonk
      • Apr 2014
      • 182
      The 4-pin mobo connector only fits in slots 5 to 8. Is that normal? IIRC, the 4-pin PSU did not work, but an 8-pin PSU did work. Unfortunately, I only borrowed the 8-pin PSU, and lost the opportunity to buy it.
      I just powered it up with the 4-pin in slots 5 to 8. I got a display but the fan did not work. The CPU fan gets power from a connection on the mobo.
      • c_hegge
        • Sep 2009
        • 5219
        I had an Intel D975XBX2 which would refuse to POST if you used a 4-pin CPU connector. The majority of motherboards, though, will work fine with only 4 pins connected.
        The thing is, though, virtually all new PSUs have an 8 pin EPS12V CPU connector, so I don't know what you meant by hard to find and expensive.
        see http://www.newegg.com/Product/Produc...82E16817151148. Dirt cheap, reasonable quality and it has the connector.
        • binsonk
          • Apr 2014
          • 182
          Thanks for the link, c_hegge. It's sort of the point of this query to find out about the even cheaper adapter.
          • c_hegge
            • Sep 2009
            • 5219
            It would probably work too, but I prefer to avoid using adapters where possible in favour of a PSU which has all of the required connectors
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Get a used unit with an 8 pin. They used it for a reason, and that is current draw. Otherwise, especially with heavy use, you'll overload the adapter's connector and the 4 wires trying to carry the current of 8.
              sigpic
              (Insert witty quote here)
                • 30963
                it's possible that the 12v pins on the gfx card are not all linked and some are directly driving different parts of the card.
                that would be a poor design, but it sounds like what's happening.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Depends on the CPU. Something such as an E6600 does not need an 8-pin connector to power it, regardless of what motherboard it's installed in. With an OC'd 125W CPU, though (Core 2 Extreme for instance), then yes, you would want to use an 8-pin connector.
                  • binsonk
                    • Apr 2014
                    • 182
                    Oh my, I wasn't satisfied with the cooler and fan on it, so I swapped in a stock Intel cooler, and now the CPU fan works with the 4-pin mobo connector in slots 5 to 8 (?). I think I can make a box now.
                    • omendata
                      • Jun 2015
                      • 25
                      • United Kingdom
                      The 8 pin converter works fine just remember it is sucking more current from a single power line on the psu so dont overload your psu.
                      You are only too old when you say you are too old!!!
                      • Compgeke
                        • Feb 2014
                        • 524
                        Not sure which pins it is off the top of my head but it'll only fit in one position, won't fit aligned over the others.
                        • binsonk
                          • Apr 2014
                          • 182
                          I got a new toy. I don't have many units with specs this good.
                          Zotac mainboard
                          2.6 GHz Dual Core
                          nVidia display
                          1 GB DDR2 / 800 MHz FSB , 128 MB onboard video (VGA)
                          VGA & Digital Video, onboard connectors
                          HDMI onboard
                          4 SATA drive slots
                          I'm running a liveCD of Linux. Look Ma, no hard drive!
                            • 30963
                            you should double the ram - other than hat the specs look good.
                            • binsonk
                              • Apr 2014
                              • 182
                              If I spend any money on this unit, first priority will be the correct PSU with 8-pin mobo connector. I don't know many distros of Linux that would falter with 1 gig of DDR2.
                              • binsonk
                                • Apr 2014
                                • 182
                                What about these two designs?
                                1 http://www.ebay.com/itm/6-Server-Mot.../121731664839?
                                2 http://www.ebay.com/itm/4-Pin-Molex-.../321229806421?
                                • Stefan Payne
                                  • 1267
                                  At least, better put 4Gig in there...
                                    • 30963
                                    Linux isnt so greedy with ram
                                    • binsonk
                                      • Apr 2014
                                      • 182
                                      I dropped by the local computer repair shop to look for a 4-to-8 pin adapter. The man said of the 8-pin mobo connector that the other/extra 4 pins are to power a graphics card, implying that the motherboard is adequately powered by the 4-pin connector.
                                      • Stefan Payne
                                        • 1267
                                        oh dear...
                                        I'm out of words for that...
                                        And no, it is not. It is for the CPU, most likely not GPU...
                                        • 5mall5nail5
                                          Help identifying connector for ASUS 4090 Strix RGB LED connector
                                          by 5mall5nail5
                                          Hi All -
                                          I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                                          Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                                          05-04-2025, 07:47 AM
                                        • RandoomStyle
                                          Gigabyte 1660 Super OC 12V Short 8pin connector
                                          by RandoomStyle
                                          Hello i got a card with 12V short, found an IC blown Q510, remove it short persist, found that the short is on 12V GPU, remove all the Mosfets and the short still there, i inject 1.5V to the line and i got 1A of consumption, nothing getting warm, this could be the GPU itself?...
                                          12-21-2024, 08:42 PM
                                        • debidoobs
                                          RX580 Pulse 8gb Gpu fixing and power rails
                                          by debidoobs
                                          Hello guys,
                                          im actually trying to wake up a non powering up gpu, model RX580 Pulse 8gb. I have a multimeter and 3 lab PSU. I mention 3 lab psu because i don't have mobo so here is the situation. I followed step by step the video from here (https://www.youtube.com/watch?v=supu7YeNTfw), he does another one about the 1.8V regulator possibly guilty, In both scenario, as me, No vcore voltage but no short anywhere. But in his case he s plugging the gpu to his mobo and the 8pin connector as well when for me, for the moment as i don't own mobo, i just inject voltage from the 12V rail from...
                                          11-11-2022, 10:51 AM
                                        • michhak
                                          Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                                          by michhak
                                          Hi guys,
                                          i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                                          It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                                          11-17-2021, 05:45 AM
                                        • m1ch43lzm
                                          70mai Dash Cam A510 - help identifying connector on camera module
                                          by m1ch43lzm
                                          Hi everyone
                                          I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                                          The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                                          I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                                          05-11-2025, 06:02 PM
