Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Old 09-07-2015, 12:07 PM   #1
slipstream55
City & State: Gilbert/Arizona
My Country: United States
Default ASUS A8N-SLI Premium re-cap questions
Happy Labor Day to one and all.
It's Labor Day and I'm doing what all men do on Labor Day. I'm laboring. At the moment, I'm laboring on my desktop PC that won't boot past the splash screen (Windows XP Pro). I've done enough troubleshooting and visual inspecting to narrow it down (at least for now) to 9 bulging/leaking KZG caps on the motherboard.
All but one of the caps are located around the CPU. The ninth one is located at the upper right corner of the board. The cap values in question are 820uF (8x12) and 1500uF (8x20), 6.3V, 105 degree caps. I would like to replace just these nine caps for now to see if doing so will bring the board back to life. If it does, I would go ahead and consider replacing the rest of them.
After doing a search on the Badcaps forum, I've seen that Rubycon MCZ, Panasonic FM or Nichicon HM/HN series caps are recommended but the posts I found this info on are old and maybe no longer valid. I did find a source that has the following parts available:
Panasonic EEU-FM0J821L (8x15) for the 820uF cap and Panasonic EEU-FR0J152L (8x20) for the 1500uF cap.
Here's where I could use some help/advice. Can anyone verify that the above parts will work or, if not, what parts will work and where to get them? Thanks in advance for any help.
BTW...I have swapped/minimized the memory modules, tried a different hard drive with a mirrored version of the XP OS and it still won't boot past the splash screen. All of the board LED status indicators are indicating normal operation, the board posts (beeps) normally. Just won't boot. I have not re-greased the CPU yet or tried to boot from the DVD drive with the XP disk. Can't do either now as the PC is apart but the nine caps I found bulged are obviously bad.
Mark
slipstream55 is offline   Reply With Quote
Old 09-07-2015, 01:45 PM   #2
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Default Re: ASUS A8N-SLI Premium re-cap questions
If you do a search for A8N* and below the search box tick: "search titles only"
Then you will get allot of hits, maybe browse through them quickly and see if you find anything relevant... (Maybe you already did?)
But generally people recap the CPU VRM area with polymer caps on newer boards like this, it's up to you though.
Since you say it still boots I'd say it's close to 100% that it will be fixed by a recap.
But you should replace all KZG caps on the board!
http://www.badcaps.net/store/product...products_id=76
http://www.badcaps.net/store/product...products_id=39
Old 09-07-2015, 05:25 PM   #3
c_hegge
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
It may be the caps, but it may also be the chipset. Nvidia chipsets from this era are all affected by what is known as the 'bumpgate' defect (essentially, where the chip's substrate material melts at a very low 60*C, which the chips often run at)
c_hegge is offline   Reply With Quote
Old 09-07-2015, 07:51 PM   #4
delaware74b
delaware74b's Avatar
City & State: Delaware
Line Voltage: 480VAC 60Hz or Less
"It may be the caps, but it may also be the chipset. Nvidia chipsets from this era are all affected by what is known as the 'bumpgate' defect (essentially, where the chip's substrate material melts at a very low 60*C, which the chips often run at)"
I thought the nForce4 MCP chipset was one of the few chipsets that didn't have that issue. The chipset in the OP's board is 'cool pipe' cooled, no heatsink, or fan. The heatpipe goes between the CPU and the VRM section and is actually cooled by the air moving out of the CPU heatsink. Yeah. Right. Probably not as effectively cooled as my old A8NSLI Deluxe. It has a tiny 40mm fan on top of the nF4 chip. I would be checking the condition of that heatpipe and the CPU fan.
A recap, replacing all KZG's is in order for this board. IMO, I would pull the trigger and recap if it was my mobo.
Stupidity should be a crime, especially for drivers. I have NO patience for them.
delaware74b is offline   Reply With Quote
Old 09-07-2015, 08:07 PM   #5
Wester547
City & State: CA.
My Country: USA.
Line Voltage: 120-125VAC 60Hz.
According to Unique (who I don't doubt), the bumpgate defect actually goes all the way back to the GeForce 2, maybe even all of nVidia's BGA chips prior to the corrected GeForce 9 series if that's really true. I wouldn't be surprised if nVidia's choice of underfill material was always poor for their chips, just that only in more recent years have the thermal cycles been wide enough and harsh enough to exacerbate the issue that c_hegge speaks of (temperatures of 60*C slowly softening the underfill and 80*C and higher turning it to mush, essentially).
+1000. KZGs are very failure prone capacitors, even in storage.
Wester547 is offline   Reply With Quote
Old 09-08-2015, 11:37 AM   #6
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist Tech
+ over 9000! i was once at an electronics shop and i saw they had about 100 kzgs in their shop stored in a plastic drawer. many of the kzgs were bulged and were leaking a rusty looking goo and the shop assistant was grumbling about caps going bad on their own without being used and causing a loss.
so i told em not to get anymore kzgs cause those are known bad caps and they are known to fail even without being used in storage. the assistant thanked me for the info. next time i went there, i saw they had gotten rid of the kzgs and gotten panny FJs and FLs instead. heh.
ChaosLegionnaire is offline   Reply With Quote
Old 09-27-2015, 02:46 PM   #7
slipstream55
Just ordered the following caps:
EEU-FR0J821 (Digikey P14360-ND) 8x13 .056Ohm $0.49ea
EEU-FR0J152L (Digikey P14363-ND) 8x22 .03Ohm $0.65ea
I think these will work. If the board boots, I'll replace the others.
Old 11-10-2016, 11:04 AM   #8
felix
City & State: Athens, Hellas
Hello, i am in the process of re-capping and further troubleshooting a A8N-SLI premium.
Are there any schematics available ? I am diagnosing a short-circuit in a pair of capacitors near the NF4 chip
felix is offline   Reply With Quote
Badcaps.net Technical Forums 2003 - 2021
