HELP! Strangest HW problem I have seen since the 8-Bit days.
  • dkolacz
    • Sep 2015
    • 5
    Hello All!
    I am brand new to this forum and found you all from a quick Google search. You guys seem to have a more seasoned group of enthusiasts than some of the more mainstream hardware sites and am hoping to get some insight for undeniably the strangest problem I have ever come across.
    My name is Dan, and I have been working with computers since the Atari 8-Bit days. I fondly remember the Atari/Commodore feuds, running a BBS from my bedroom, and 127 Kilobyte disks that took 6 hours to transfer over the phone lines!
    I am a PC tech, but not to the mobo component level, so I don't know if this problem is even fixable. This issue is absolutely baffling to me, but it may be elementary to Badcaps forum members.
    I have an older laptop from 2008 that has been running fine up until a couple months ago. I am very fond of this model and would love to salvage it if possible.
    In a nutshell, the laptop will just power off (no bluescreen, no errors) if the CPU is not getting taxed.
    When windows comes up, I have to immediately start a 720P video or run a game in the background and then it will stay powered on. It seems like I have to keep the CPU at a constant 60% or more utilization. I can then browse the web, run other programs, etc. If I close down all open programs, the laptop will power off within seconds/minutes.
    My troubleshooting steps so far:
    It is not overheating as HW Monitor reports normal and I have re-pasted everything.
    I have swapped out RAM, and hard drive.
    It happens when just the battery is supplying power.
    It happens when just the power cord supplying power.
    It happens when both the battery and power cord are used.
    It happens when the singular hard drive is removed and boot Linux from USB.
    This can not be an OS problem because when I swapped the hard drive, I tried reinstalling Windows 7 and it powered off during the initial setup phases in the partitioning section. After several tries, it eventually installed without rebooting. I have also tried Live CD Linux distros and it shuts off in them as well.
    --==< *** Now it gets really strange *** >==--
    If I boot into BIOS, MemTest, DOS, or the Hirens/Falcon4 CD and boot into mini Windows XP, it will stay up FOREVER!
    So what is different in these environment? I am thinking because these environments don't support different power management states of the CPU? VGA video only? I don't know if this is correct, but I am at a loss.
    I tried messing with the power settings in Windows and tried Balanced, High Performance, etc. I changed the min/max "processor state" in Advanced settings to 100% and it didn't seem to help.
    I have not tried swapping the CPU yet, as I do not have one readily available. It would be rather anti-climactic to me if this is it.
    If this post would be better off in another forum area, and the mods would like to move it, please do!
    Anyone have any ideas?
    • 30977
    Re: HELP! Strangest HW problem I have seen since the 8-Bit days.
    swap the harddrive.
    • c_hegge
      • Sep 2009
      • 5219
      Read the post first.
      As for the shutting off problem, though, I have no idea. I've never seen or heard of it. The only other thing I can think of is trying a new CPU. What brand and model is the laptop?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        My crystal globe says it is a Toshiba Satellite A300 or L300 or similar, and that you are experiencing the Nec/Tokin capacitor issue. There is a very big thread on how to fix that.
        A working TV? How boring!
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          i concur, it sounds like bad caps to me. it is true that bios, memtest, dos and mini winxp dont support cpu multiplier and vid based throttling states.
          thus the cpu needs to run at above a certain temperature in order to "heat up" the bad caps. the warmer the caps are, the lower the esr. thus the system runs great when u partly load it up. but if it idles and/or throttles down to the lowest multiplier and voltage, it cools down and the esr of the caps rises and the circuit goes out of spec.
          also, i vaguely remember in the datasheets for some intel cpus, the vrms can send a signal to the cpu telling it that the vrm is running improperly. depending on the condition, the cpu can then tell the vrm to shut down. this safety feature protects the cpu from dmg due to out of spec supply current.
          please list all the detailed specs of your laptop like the unique said. also, if u are able to, open up your laptop and snap pics of the mainboard and capacitors and post it here.
          • dkolacz
            • Sep 2015
            • 5
            Sorry for the delay getting back....had the time to tear it down yesterday.
            Un1qu3's crystal ball seems to be correct! Thanks for that.
            It is an Acer 6920. It has the 0E907 under the CPU.
            I attached some photos.
            I have never done any type of repair like this, but I have a friend who thinks he can help.
            I have read through some posts, and seen some videos....
            Some say use a heat gun to remove the 0E907...some say use pliers to yank it off.
            If the heat gun is used, do I have to protect components around it? Will other things be melted?
            We only have a heat gun and soldering iron...no IR or BGA station or anything like that.
            If someone has a link to correct instructions, and what replacement caps I should be buying considering our equipment, that would be fantastic.
            I saw several SMD 330uf 2.5v tantalum on ebay...will any work? or specific brand/size/design?
            Thanks!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Ahh, a 6920. Done a couple of those as well. That one will require six 330uF capacitors so you have to be clever with placement. Or you can use four 470uF.
              Do not use the heat gun on it, you may damage the CPU socket. You will just need a wide chisel tip for your iron, to be able to heat a large area at once so you can successfully solder the new caps in.
              To get the Tokin off, use a pair of pliers to crack it, then take a sharp blade and peel it off the board in layers. It is fairly easy to do, just take your time and do it carefully, you don't want the blade slipping and taking other parts off the board. After you get all the remains of the Tokin off, scrape away some more of the solder mask to make room for the new caps. Just make sure you check the polarity before you start soldering.
              If you need any more assistance please let me know.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                the boy genus does it again
                • dkolacz
                  • Sep 2015
                  • 5
                  Thanks for the great info....I just love this laptop and want to keep it in service...beautiful 1080p screen, blu-ray, fingerprint, great sound...
                  I am curious as to why the Acer needs 6 caps instead of 4? I saw many "kits" on ebay to replace NEC/Tokin and they all had 4x330uf. I am not questioning your accuracy....this is all new to me and a learning process.
                  example: http://www.ebay.com/itm/4x-SMD-Tanta...-/330953629462
                  Also, are there any other criteria for the 470uf? I just did a search on eBay for "470uf" and there are a bunch...most are the round variant with 2 leads sticking out.
                  Thanks!
                    • 30977
                    your matching the capability of the faulty part.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      If you keep having issues with just 4 of them, then going to 6 will make it work 100%. I had one where someone else had already installed 4x 330uF and the laptop was still acting up. I added two more of my own, et voila, magic...
                      But again, this is using parts scavenged from mainboards, so maybe they were weak to begin with.
                        • 30977
                        best thing is to not use ebay and to get surfacemount caps tant or poly with the lowest possible ESR
                        or get the prodalizer datasheet to see what the original thing was.
                        • dkolacz
                          • Sep 2015
                          • 5
                          So far so good. Just waiting for the SMD's to arrive.
                          I successfully removed the old Tokin chip from the 6920 with pliers and blade.
                          There are 4 sliver colored strips remaining where it used to be. I have noticed that in some strips, it has dullish grey color, and other places it is shiny silver. Did I dig too far with the blade to produce the shiny silver or should it all be like that?
                          Also, when I solder the new caps, do I have to ensure that the solder does not touch between the 2 caps on each side or it does not matter?
                          Thanks again for everyones help! I thought I was never going to be able to fix this thing.
                          Dan
                          • joshnz
                            • Feb 2011
                            • 969
                            • New Zealand
                            might need to provide a picture.
                            My pc
                            CPU : AMD PHENOM II x4 @ 3.5Ghz
                            MB : ASUS M4A89TD PRO USB3
                            RAM : Kingston ValueRAM 16gb DDR3
                            PSU : Cooler Master 850W Silent Pro
                            GPU : ATI Radeon HD 6850
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              Search for "proadlizer" to understand its structure. The two + strips and the - rectangular belly plate can be removed by lifting an edge with a sharp tool then peeling it off.
                              Do not use a soldering iron or do any messy scratching at this stage.
                              Look at these threads to get a better idea.
                              https://www.badcaps.net/forum/showthread.php?t=46821
                              https://www.badcaps.net/forum/showth...highlight=a200
                              You must not cause any short circuits when fitting the new capacitors.
                              • theone111
                                by theone111
                                3. Problem: TV shuts down
                                07-22-2024, 10:36 AM
                              • Zeonalbasta
                                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                by Zeonalbasta
                                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                09-13-2024, 01:17 PM
                              • Gibon378
                                Problem with stopping audio and video for no reason
                                by Gibon378
                                PC Specs:
                                • CPU: Ryzen 5 1600
                                • GPU: GTX 1080 Palit JetStream
                                • MOBO: ASRock ab350 PRO4
                                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                • PSU: XFX 650W (don't remember what model)
                                • OS SSD: ADATA SP920
                                • OS: Windows 10 21H2
                                Problem description:
                                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                11-19-2022, 09:41 AM
                              • perzyk23
                                Lenovo T580 - LCD Panel problem - error 0288
                                by perzyk23
                                Good morning,
                                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                10-25-2024, 12:42 AM
                              • SDNarcia
                                Dell 15R-5521 keyboard problem (KBC?)
                                by SDNarcia
                                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                As additional information,...
                                07-20-2024, 10:47 PM
