Lenovo E570 NM-B421 Turns on then off.
    Can I please get some help, I can't figure this out.
    Board: NM-B421
    Model: Lenovo ThinkPad E570
    Charger plugged in, flashes 3 times. Power button pressed, it turns on 2 seconds then off. Occasional fan spin slightly until it turns off again. Never more than 2 seconds.
    Attached PDF shows readings I gathered.
    Things tried:
    Flashed 5 different BIOS files, original bios dump + 5 others linked, schematics and board readings are all here:
    https://drive.google.com/drive/folde...US?usp=sharing
    Here is the video of the fault:
    https://youtu.be/OB6xf7211Mg
    Aditya11ttt says on a forum:
    'In this board u don't need to program io it will program auto , but still it's a theory u should try to program and update me it's done or not !!"
    Attached also the image of the board with readings.
    Anything else I can try? Thanks!
    Re: Lenovo E570 NM-B421 Turns on then off.
    PQ301 Mosfet is playing weird. I've replaced the Mosfet already. The PU301 which is a RT8231AGQW is acting up I suspect. See measurements.
      Sorry this is the correct readings.
        I had similar experience with HP laptop, on 1-2 seconds and then off again. All voltages are present. Scratching head for a while before I discover the issue is due to faulty DRAM. Not sure if you have try replace the DRAM with known good DRAM.
          You mean Dram controller? Ram is replaceable. Tried different ram.
            Board: NM-B421
            Things tried:
            'In this board u don’t need to program io it will program auto , but still it’s a theory u should try to program and update me it’s done or not !!"
            anyone fixing this issue and stuck at this point of reading should check if the cpu pwm NP81218 is receiving the 5V (vcc) on pin#13, if not measure for short or replace ic.
