where to find a good supplier for smd parts
    Hoping to find a good laptop parts, battery, lcd , etc for bussiness, a small bussiness.
    Re: where to find a good supplier for smd parts
    Aliexpress is great for the parts / LCD, etc. While we have had good luck with battery sourcing as well, shipping laws may delay or restrict the importing of batteries to your region (fire hazard). Locally we have Moble Sentrix and love their service. You probably have someone local to you or you can try Amazon. The benefit of Amazon is that you can return the part as customer is #1 (even when they are wrong). As a reseller on Amazon, we have been scammed many times with 'did not receive the goods'. In one case, found out the customer is in an apartment and their front desk concierge signed for the parcel. We contacted the concierge, who repeated that the customer is well aware of this same procedure to receive goods. We mentioned that a police case will be filed - customer backed off immediately.
      Always have bad battery like AS16A5K and some acer built in batteries. Hope you can drop links
        Try this store - the ratings and sales volume are high. It is faster to source from Amazon if the vendor has stock closer to you but sometimes, even the Amazon vendor is in China or elsewhere.
        https://www.aliexpress.com/item/3291...d=bK6S4BWhAnih
        Post your updates here. Our experience, in general, has been very positive with Aliexpress and Alibaba vendors. Open dialog is important to be sure you are buying the proper product. Be sure to confirm this before ordering.
        Ask them again, what is the warranty and policy if the battery does not work. If you are finding repeated faults with the battery sourcing then the issue may be with your charging circuit / logic board so that should also be reviewed. That is, not every battery will be crap.
          thanks for the link, ive experience lots of bad battery cells , ive been using this NLBA battery tester https://www.laptopu.ro/
          to confirm if battery cells will last or calibrate the battery properly..
            We purchased the same tool when we thought we had a bad batch of battery packs.
            Post the details on how you are using this tool to conclude if the pack is defective or of quality or not.
            For us, the true fault was with charging circuit of the logic board.
              you always incounter this type of issue? sometimes battery wont be detected but can be detected with nlba tools, im very new in this type of tool. I just only use the autocycle to determine its real capacity. If the batetry is labeld 2900mah but tools detected a 2500mah that for me is good. but if battery is detected with 1800mah that's a bad sign. Also checking the cells check cability of the tool. if its good cells, poor, or bad. Sometimes it detected a poor cells but capacity is in good value it can be sold to the customer.
                also where to find a good new laptop motherboards that sold in aliexpress. I only have access with aliexpress
                  No it's not great. Insane amount of fake, counterfeit or low quality products as well as used or already broken products advertised as new.
                  Sometimes you don't even receive the product you have ordered.
                  If you open a dispute, sometimes it goes through easily, and sometimes you won't win whatever you do, and it's always a huge waste of time.
                  Also language barrier is an issue, and most sellers do not care about what they sell.
                  It's only a solution because lots of stuff cannot be found elsewhere.
                  Some sellers may not be too bad, but that's definitely not all of them, and even then it doesn't mean that every product they sell is good, far from that.
                  For some products the market is so bad that it's very difficult to find a reliable source, batteries are probably among the worst offender.
                    thats the hard part of starting a bussiness, not finding a good supplier..
                      Try Mobile Sentrix who has their HQ in the USA. They are shipping internationally. We have purchased our batteries and assorted parts for repair from them many times and without issues. They also will take back returns without penalities. Review their website for more information.
                      If purchasing semiconductor parts, post the requests here and can share from where we have purchased our inventory from in Asia.
