Lenovo Z580 led flashing then off
    Hello i got this lenovo z580 when you press the power button led`s are flashing then imidiatly off, you can press the power button again it always flashes then off. What i've tried so far:
    flash EC & Bios
    Reflow chipset
    Remove Network IC and Sound IC
    Re: Lenovo Z580 led flashing then off
    Some secondary power rail shorted? Tried to measure gpu, cpu, pch rail resistance?
    Is there enough time to measure secondary voltages to see which ones come up?
    Another cpu? Without memory?
      tried everything already also no short voltages are there, i think its the chipset that is faulty.
        It does sound like GPU failure. Try a more aggressive reflow or reball (preferable).
          i need bios dump of z580 , please upload robrock1
            so did u slove it .i also have same problem with same model when i run it without ram it works and does not goes off but if pluged memory it turns off imidiatly
              i need bios files please
                anybody
                  here bios dump
                    thanks boss
                      u must have some short maybe a capacitor in memory power rail
                        in my case i found one brown capasitor near right click button was leaky, t shows 4 resitons on buzzer mode.of multi meetar.
                          Have same problem did u fix??
                            whether this bios responsible for ideapad Z585?
                              Finally what was the problem, i have the same issue..
                                Had same problem reflash bios or change ,there 2 bios chip i had case that one is ok second is bad after replacing them laptop works fine
                                  The problem solved! Thank you very much. I changed also both 2 bios chip. THANK YOU !!
                                    did u try to look after bios communication?
                                      plz help me ...i need a bios lenovo z480
                                        i was the same problem with led flashing an then turn of , i fix wit bios flash an than work fine , and than i pull out power cord whit batery inside and the laptop turn off automatical , now i hawe short circuit on main rail , i verify many capacitors withouth find the short circuit , i hawe short circuit on sideback of gpu motherboard maybe the cip is shortcircuited but i"m not shure , anybody knows any schematic diagram for this model , thanks
