Need bios hp la-e841p
    Hp 15 la-e841p
    bid08330
    thank u
    Re: Need bios hp la-e841p
    Download the bios,run the .exe ,it will give you the option to save the new bios.
    https://ftp.hp.com/pub/softpaq/sp965...00/sp96845.exe
      my computer does not turn on so i need dump thank u
        Run the exe on a different pc/laptop . Don`t you have access to a windows machine ?
          thank u its ok
            Re: HP 15-bw049ur acting strange
            Need Both EC and Main BIOS Please
              ok here .
                excelent, working
                  thanks
                    Originally posted by zmedia View Post
                    Hp 15 la-e841p
                    bid08330
                    thank u
                    good
                        Originally posted by islammostafa.me19 View Post
                        tested Attached Files
                        File Type: rar HP 15 bw series LA-E841P Rev2.0.rar
                        it works. thanks
                          tested
                          it works. thanks
                            it works. thanks
                            ENE is for EC? how can I reprogram that one?
                            I flashed another bin from another threat but it shows Manufacture Programing mode is in Unlock Mode and fan is running 100% all the time
                            Any advice? thanks!
                              Any advice? thanks!
                              post the full name and model of the laptop and the backup of the original bios
                                Hi! thanks for the response!
                                The laptop is "HP Notebook - 15-bw014la"
                                Here is the original bios also...
                                  use the bios from post # 7 ... 08330 ..
                                    I am pretty sure, I used that one, but lemme try again later that I get back to my place and I'll inform the results
                                      Hello Again, I just flashed BIN from post 7, 08330
                                      I shows 2 times "Flashing Boot Block" to 100% and then boots, still shows the message "Manufacture Programing mode is in Unlock Mode"
                                      Also, it wont boot from any HDD, or USB now, it simply jumps to:
                                      "Boot Device not found"
                                      Hard Disk (3F0)
                                      F2 System Diagnostics
                                      If I hit F2 and go to HDD test, it shows SMART Test Pass and show a progress bar, so It is detecting a HDD apparently, It just wont boot from any device
                                      No matter what I plug, HDD or SSD or USB , any advice?
                                        I flashed this BIN file I got from a Discord group, It allowed me to boot and SSD and USB is detected, but Fan still 100% all the time, Fan Always On setting in BIOS is set to Disabled
                                        And "Manufacture Programing mode is in Unlock Mode" also showing
                                        Advice? thanks!
