hi all i want dump for HP ProOne 600 G2 21.5-inch Touch All-in-One PC quickly please
need bios HP ProOne 600 G2 21.5-inch NonTouch All-in-One PC
Re: need bios HP ProOne 600 G2 21.5-inch NonTouch All-in-One PC
Originally posted by nyknemesis View Postyou mean replace the bios chip with another and eraser whatever was on it and write one of the above?
because the dump i posted was from the original chip.
Yes, my brother, replace the chip with another, be the same size
Get one of the old motherboard
helo guys. problem solved, you have to clear me region from the bios (Google how ) NONE of the bioses posted here are cleared. i have atached a clear bios but if it dosen't work for you download the HP ProOne 600 G2 fixed posted above, and clear it you're self it will work. after boot you will have a msg booting to factory mode 30 seconds, just update bios normaly in windows or from bios.Attached Files
Hi
I have a HP ProOne 600 G2 that is beeping 4 times with power led flashing. I do not know if the bios is the root cause of the issue. I have attached the bios that I have read from a Winbond W25Q128BV chip.
Please confirm if the bios is a valid one.Attached Files
HP ProOne 600 G2 21.5-inch Non-Touch All-in-One PCAttached FilesLast edited by SMDFlea; 10-29-2019, 06:38 AM.
Thank you @SMDFlea for the prompt reply.
I have tried the bios that you sent, but the behavior is the same. There are 3 long beeps(led on the power button is flashing red 3 times) followed by 4 short beeps((led on the power button is flashing white 4 times) and the fans are not spinning. This HP ProOne 600 G2 has suffered a power surge, together with other similar PCs. For some of these PCs, I have found some short-circuits on the power supply phases for processor, that have disappeared after I have removed the processor from his socket.
Is it possible that the beeps are showing a hardware failure for some chip-set on the motherboard or even some hardware failure of the processor itself?
For the "beeping" board I have discovered the root cause of the beeps: The processor was missing. I have put a G3900 on this motherboard and it is working OK, also the bios from @SMDFlea.
Does anybody know if the processor G4560 is working with this motherboard? I have found on Q150 chip set specs (on http://www.cpu-upgrade.com/mb-Intel_...ets)/Q150.html ), that it is supporting this processor.
