Dell Latitude e6320 charge circuit broken, bypass ?
    Hi All
    I have a laptop what does not charge anymore, it won't go on without battery.
    But even with a "dead" battery it will go on and works fine, aslong there is a battery in. In the dell bios it show no adapter installed, also with a universal adapter same, but does boot, but does not charge and won't go on without battery.
    Now I have read: https://www.badcaps.net/forum/showthread.php?t=44259
    and it points to PU14 / CD3301 CD3301RHHR_QFN36_6X6 and indeed that chip has some burn marks on pin 34.
    According to the schema it should be DC_IN_SS, I could try to replace the whole chip but:
    is it also possible to bypass or make a wire to pin 19 (+NBDOCK_DC_IN_SS) ?
    so the laptop thinks it is docked (but is powered by adapter plug) and will charge ?
    thanks in advance.
    Re: Dell Latitude e6320 charge circuit broken, bypass ?
    maybe a stupid question but if I google on CD3301RHHR I see multple chips but the lower numbers does not match or is that the serial of the chip besides G4 ?
      CD3301-This should match, rest is irrevalent as they are date codes etc.
        Have Brocken Pin 36. 😅
          Help my to find new Pad for cabl to Pin 36
            Check this pic, solder chip without this pin is Ok
              Not Pin 36 sry Pin 34 and 33
                Make a wire to this 2power rezistor
                pin 34 - PR302
                pin 33 - PR299
                  I Have a same problem with E7440 but in my case
                  Is a Pin 6
                  How i make bypass
                    Help Me Please
                    LA-C621P
                    How To Bypass
                    CD3301B Heating
                      Dell Latitude E6220, The CD3301 is burn, Can I replace with CD3301B or not?
