Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Thread Tools Display Modes
Old 10-20-2019, 02:05 PM   #121
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Cyberpower PR1500 won't charge battery
Sometimes chips will go faulty and overheat by themselves.
__________________
-David VanHorn
Agent24 is offline   Reply With Quote
Old 10-20-2019, 03:01 PM   #122
electronicsuk
City & State: Lincoln
My Country: United Kingdom
I'm a: Knowledge Seeker
Quote:
Indeed, although probably not this time. I forgot to mention on my first post thay I also replaced the optocoupler on the SMPS. I've just checked back at some photos I took of the PCB before I started, and it looks like the opto should be a Cosmo K1010C. I've fitted a K1010B. The datasheet shows the 1010B has about 50% of the current transfer ratio of the 1010C, so I suspect it's an issue with incorrect feedback to the Viper.
I suppose this is karma for my lazy repair technique - if I'd spent more time fault finding than replacing lots of components that *might* be the problem, I probably would never have replaced the opto in the first place!
Sadly I can't easily get a 1010C in the UK so I've had to order some from China. I'll report back with how I get on. Will probably replace the Viper as well, just in case the thermal overload has caused any damage.
electronicsuk is offline   Reply With Quote
Old 10-20-2019, 03:01 PM   #123
sam_sam_sam
City & State: Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Check and make sure that you do not have a short some where in battery charging circuit or circuits that might why you are seeing the charging current going up and down might be the reason that the Viper 22A is running hot or it could a bad chip however if change it and still run hot I would looking for something low ohm short
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 10-20-2019, 09:31 PM   #124
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Can we see good clear pictures of the whole top and bottom side of the board?
__________________
budm is offline   Reply With Quote
Old 10-21-2019, 10:58 AM   #125
budm
budm's Avatar
My Country: USA
BTW, you should also make new thread since your model is not the same as OP.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
