Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 06-27-2019, 02:14 PM   #3781
Curious.George
Default Re: best cheap/free scores 1.1
4 10' two-headed 16AWG power cords (for my SANs)
Curious.George is offline   Reply With Quote
Old 06-27-2019, 06:21 PM   #3782
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Originally Posted by Topcat View Post
I was given (took in trade, sold client a newer/faster one) a mint condition Inspiron 1300 laptop with charger & Dell case. Has a single core celeron @ 1.5GHz and 512mb RAM in it. I got the max CPU (Pentium-M 780) @ 2.26GHz and 2gb RAM for it for $20, which is probably about all the system is worth....but given its pristine condition, batt is good, and it works...what the hell.
This post created from this laptop. Maxed out CPU (Pentium-M 780 @ 2.26) and memory (2gb), and actually runs Win7 ok....not great, but ok. The biggest hangup is the 915G GPU, while I found a driver that will work (no official support past Vista, and that was sketchy to say the least), it just doesn't have the stones for Aero....even getting it to work was tricky....so I just set it up with the stellar XP-look.....and here we are from FF56.0.2.
The one thing this one had over most laptops, CPU swap was all of 6 screws. Two that held the cover plate on, and four to remove the heatsink.....they should all be that easy!
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 06-28-2019, 05:52 AM   #3783
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
My latitude E6430 is four screws... as is my Asus X83V. Not common but such designs did continue to exist.
(Insert witty quote here)
ratdude747 is online now   Reply With Quote
Old 06-29-2019, 09:53 PM   #3784
LLLlllou
City & State: NJ
Originally Posted by momaka View Post
I think the VooDoo3 graphics card is very likely FUBAR. What I thought was a small scratch on one of the RAM chips is actually a crack, I think. The way I checked: I used a screw driver to scratch the RAM chip in a direction perpendicular to the scratch, and I kept "feeling" the scratch no matter how deeper I went. If that's the case... only remedy would be to find some old SDRAM sticks with 16 Mbit chips... which I have NONE at all. Might put a post up in the "looking to buy" forum when I get to it and confirm if that RAM chips is bad or not. If it is, it's going to be a RAM chip replacement job + who knows what else. But for a VooDoo3 card, I think it's worthwhile.
Got any old 40GB Maxtors laying around? Looks like they use the same Micron RAM.
https://forums.tomshardware.com/thre...stance.674440/
LLLlllou is offline   Reply With Quote
Old 06-30-2019, 05:52 AM   #3785
Dan81
SNES-powered
Dan81's Avatar
City & State: Romania
My Country: Bacau
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Got a free 486 motherboard I can't for the life of me identify (UMC UM8498F, 4x ISA, 3x VLB, 72pin SIMM) with removed cache slots (I think I have some old boards I could remove the sockets from ) and a Gigabyte H61M-S1 that appears to be dirty to all hell, and may be dead as well.
Main rig:
ASUS H61M-A
Core i3-3220 3.30GHz
MSI Twinfrozr GTX 750Ti 2GB GDDR5
6GB DDR3-1066
Samsung SH-224AB DVD-RW
Raidmax RX-500XT (recapped)
Seagate Barracuda ES.2 ST31000340NS 1TB
JNC RJA-52 case
Dan81 is offline   Reply With Quote
Old 06-30-2019, 07:54 AM   #3786
stj
stj's Avatar
City & State: Europe
id your board here:
https://stason.org/TULARC/pc/motherboards/
Old 07-01-2019, 05:37 AM   #3787
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
It's a AEI/Chicony TK-8498F.
I managed to get some beeps this morning, although nothing much than that. They're unusual for AMI BIOS - they're low in tone, while AMI BIOS uses a higher tone.
Old 07-01-2019, 03:24 PM   #3788
stj
stj's Avatar
touch the cache chips, often bad ram gets very hot.
Old 07-01-2019, 03:27 PM   #3789
ChaosLegionnaire
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
could be bad caps there! i know bad caps can change the tone of the audio on amplifier and speaker systems! same thing could happen to mobo speakers...
ChaosLegionnaire is offline   Reply With Quote
Old 07-01-2019, 11:02 PM   #3790
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Cache chips stay quite cold, and I've already replaced the caps (three caps lol, one 1000uF 10v and two 220uF 10v)
Old 07-02-2019, 03:16 AM   #3791
stj
stj's Avatar
have you got a frequency counter or multimeter that can read upto the speed of the crystals?
Old 07-04-2019, 02:21 PM   #3792
Curious.George
A pair of MD3200i's. I can fill them with 300G 15K drives (i.e., ~7TB) and use them to host the "working" copies of my VMDKs (so I can put them in a different room from the ESXi servers!)
Old 07-07-2019, 06:05 AM   #3793
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Scored a PSP model 1004 (phat) for $7. Case is quite cracked, battery for some reason won't charge on it (works on a 3004 I have tho) but otherwise it works fine. I removed the UMD drive since I don't need it (I have a 1GB MS Pro Duo stick) and cleaned the LCD.
Old 07-07-2019, 12:39 PM   #3794
stj
stj's Avatar
is the charging socket good?
i had one that wouldnt charge - the center pin was missing!!
Old 07-08-2019, 11:59 AM   #3795
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Yeah, it's good. Apparently the charging circuit didn't like the battery at first as the cells weren't active. Placing it into another PSP (a 3004) I have must've reactivated the cells as after letting it charge up until 50% I could then charge it using the 1004.
The only thing left that irks me is the wifi switch, but that may be also because of the pretty beaten up casing it has (gotta order a new one sometime)
Old 07-08-2019, 08:58 PM   #3796
Curious.George
6 mini-SAS cables -- but, they're only 2m. I guess I'll have to keep looking...
And, 15 2T, 6Gb, Dell-branded SAS drives (so, that fills another SAN shelf with a few spares)
Old 07-09-2019, 09:07 AM   #3797
Dan81
SNES-powered
Dan81's Avatar
My Country: Bacau
Free ASUS P5QD Turbo - P45 chipset, J-Micron 361 + Sillicon Image SIL5723.
Looks nice, was just dusty. Has EPS12V connector, a jumper named OV_CPU (which I can either describe as overclock), heatsinks for the MOSFETs.
Old 07-09-2019, 10:20 PM   #3798
Topcat
The Boss Stooge
Topcat's Avatar
Cheap rummage sale find....I'm normally not a yard sale guy....but when driving by and I spot this:
Yea, I stop!! It lights up and appears to work. I haven't fed it a signal yet though. It's all there and intact. One knob missing.
Old 07-09-2019, 11:19 PM   #3799
TechGeek
Computer Geek
TechGeek's Avatar
City & State: Insanely Hot Texas
Line Voltage: 118-126VAC@60hZ/200A
I'm a: Hardcore Geek
Philco Predicta. Those are PITA's to service.
For computer parts, go to Newegg
OR
Amazon.
For electrical stuff(pushbuttons, capacitors, etc), use Digikey
OR
Mouser.
Windows 10!? Oh yeah, that sorry excuse of an operating system that spies on you 24/7/365!
Samsung = Seagate = Seatrash = Trashgate
Don't buy Seagate drives. Don't use Seagate drives. If you have any in service right now, make plans to replace them ASAP.
TVs repaired: Toshiba 32AV500U
Stereo Receivers brought back to life: 1(Fisher RS-1056)
Stereos/Stereo receivers to recap: Fisher RS-1056
TechGeek is offline   Reply With Quote
Old 07-10-2019, 03:51 AM   #3800
stj
stj's Avatar
that thing looks awsome - you could probably lease it to film production company's!!
