i have a question on power supply specially in trouble shooting audio equipment/ can i use boost converter of just a linear power supply. boost converter psu has higher efficiency, current and much colder than linear psu,, what are the disadvantage of using boost converter in audio equipment. thanks in advance
Re: Anyone build their own equipment? Plans for small benchtop power supply.
Originally posted by Duranitron View Postcan i use boost converter of just a linear power supply... what are the disadvantage of using boost converter in audio equipment. thanks in advance
Are you boosting a lower voltage to a higher one? (Such as car subwoofer audio amps do.)
Or are you talking about a buck converter / buck regulator / switching regulator for lowering voltage?
I suppose that question is irrelevant, but I am just curious since you specifically mentioned boost converter and not the more generic term (switching regulator / SMPS.)
As for disadvantage of using switching regulators in audio... that depends a lot on your application and what device you're trying to power. If your audio device has anything to do with AM radio, you would probably want to avoid any kind of switching PSUs and regulators, as these tend to kill AM reception (though if carefully and well designed, it may not affect AM radio reception that much.) I ran into that problem with an old late 90's boombox that I converted to use an external SMPS adapter, detailed here:
https://www.badcaps.net/forum/showthread.php?p=997901
Other than that, and as long as the audio amp isn't overly-sensitive to noise and the switching regulator is designed to have enough filtering on its output, then you may not see that much of a difference between that and a linear regulator.
But again, going by description of what you're trying to do is rather vague, so it's hard to give a more solid answer.
