Thread Tools | Display Modes |
#1 |
ajshoe
City & State: cincinnati, ohio 45215
My Country: usa
Line Voltage: 120VAC 60HZ
I'm a: Hobbyist Tech
![]() Have a Samsung washer - top load that only starts when it wants to. Normally pushing the start button after selecting the cycle - it won't start, just beeps. constantly adjusting cycle and hitting start may get it to work. I took out the control board (wax or gum coated) - don't see anything obviously wrong. Put in another used control board - washer works perfectly (start button works).
Is there a way to remove this wax / gum off the board ( DC92-01021H) ? I'll post pics tomorrow morning. Most likely bad caps ? I read on another post - bad voltage regulator. thanks Last edited by SMDFlea; 11-24-2020 at 03:22 PM.. |
#2 |
Leaking Member
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
![]() heat that epoxy up with hot air then pick it off.
#3 |
ajshoe
My Country: usa
![]() Did back side. Not easy job.irs not epoxy - very soft. Gummy. It is clean thou. Work on top side tomorrow
#4 |
City & State: worcester
My Country: United Kingdom
I'm a: Knowledge Seeker
![]() cycle selector might need cleaning
#5 |
ajshoe
My Country: usa
![]() appears that all functions work -rotating the knob selects any cycle. the only fault is the start button doesn't start the cycle that was selected. The start button is acknowledge as I hear a beep when pressed. I can get the washer to start but is totally randomly. can't figure out sequence to get it to run consistently.
#6 |
![]() lid switch ok ?
#7 |
ajshoe
My Country: usa
![]() think you missed the earlier post - I put in a used control board from ebay and washer works perfectly
#8 |
#9 |
ajshoe
My Country: usa
![]() pics - found bad cap 10Uf 500V. replaced it - washer seems to work now. ran 3 loads with no issues.
#10 |
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
![]() Good job! where is the cap located? This will help lots of people. The conformal coating is always a pain to remove, yous is more likely to be silicone based conformal coating. Washer model number?
__________________
Never stop learning Basic LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 Last edited by budm; 11-24-2020 at 02:19 PM.. |
#11 |
ajshoe
My Country: usa
![]() in the pic - it is the cap with the black x on top of it - top of the board (actually easy to remove and install new one). thought I put model # in topic - my mistake. Samsung washer model #WA50F9A8DSW/A2. Is there an easy way to remove that silicon coating ? I spent a lot of time peeling it off.
#12 |
Leaking Member
My Country: Canada
![]() aah! Top left, first pic! Nice job!
Thread Tools | |
Display Modes | |
