Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 11-23-2020, 04:20 PM   #1
ajshoe
ajshoe
City & State: cincinnati, ohio 45215
My Country: usa
Line Voltage: 120VAC 60HZ
I'm a: Hobbyist Tech
Default samsung washer control board - DC92-01021H
Have a Samsung washer - top load that only starts when it wants to. Normally pushing the start button after selecting the cycle - it won't start, just beeps. constantly adjusting cycle and hitting start may get it to work. I took out the control board (wax or gum coated) - don't see anything obviously wrong. Put in another used control board - washer works perfectly (start button works).
Is there a way to remove this wax / gum off the board ( DC92-01021H) ? I'll post pics tomorrow morning.
Most likely bad caps ? I read on another post - bad voltage regulator. thanks
ajshoe is offline   Reply With Quote
Old 11-23-2020, 04:30 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Default Re: samsung washer control board
heat that epoxy up with hot air then pick it off.
CapLeaker is offline   Reply With Quote
Old 11-23-2020, 05:23 PM   #3
ajshoe
ajshoe
My Country: usa
Did back side. Not easy job.irs not epoxy - very soft. Gummy. It is clean thou. Work on top side tomorrow
Old 11-23-2020, 05:46 PM   #4
petehall347
City & State: worcester
My Country: United Kingdom
I'm a: Knowledge Seeker
cycle selector might need cleaning
petehall347 is offline   Reply With Quote
Old 11-23-2020, 05:52 PM   #5
ajshoe
ajshoe
My Country: usa
appears that all functions work -rotating the knob selects any cycle. the only fault is the start button doesn't start the cycle that was selected. The start button is acknowledge as I hear a beep when pressed. I can get the washer to start but is totally randomly. can't figure out sequence to get it to run consistently.
Old 11-23-2020, 06:00 PM   #6
petehall347
lid switch ok ?
Old 11-23-2020, 06:07 PM   #7
ajshoe
ajshoe
My Country: usa
think you missed the earlier post - I put in a used control board from ebay and washer works perfectly
Old 11-23-2020, 06:11 PM   #8
petehall347
Quote:
yes i missed that bit .
Old 11-24-2020, 10:17 AM   #9
ajshoe
ajshoe
My Country: usa
pics - found bad cap 10Uf 500V. replaced it - washer seems to work now. ran 3 loads with no issues.
Old 11-24-2020, 02:14 PM   #10
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Good job! where is the cap located? This will help lots of people. The conformal coating is always a pain to remove, yous is more likely to be silicone based conformal coating. Washer model number?
__________________
budm is offline   Reply With Quote
Old 11-24-2020, 05:29 PM   #11
ajshoe
ajshoe
My Country: usa
Default Re: samsung washer control board - DC92-01021H
in the pic - it is the cap with the black x on top of it - top of the board (actually easy to remove and install new one). thought I put model # in topic - my mistake. Samsung washer model #WA50F9A8DSW/A2. Is there an easy way to remove that silicon coating ? I spent a lot of time peeling it off.
Old 11-24-2020, 06:08 PM   #12
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
aah! Top left, first pic! Nice job!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
