Thread Tools | Display Modes |
#41 |
The Boss Stooge
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I'm a: Professional Tech
![]() Good call. It'd be a snap to build a basic power supply and shazam!
__________________
<--- Badcaps.net Founder & Owner Badcaps.net Services: Premade Capacitor Kits Badcaps.net Capacitor Master List Motherboard Repair Services If you've come here in search of replacement capacitors or repair services, please use the links above. ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
#42 |
City & State: BC
My Country: Canada
I'm a: Knowledge Seeker
![]() If you want to isolate the failed LED, you can use a multimeter in diode test mode. If there are no test points, scrape the soldermask beside each LED.
#43 |
City & State: Beavercreek
![]() Newbie here. I also have the Insignia NS-48D510NA15 with no backlight. I was able to take it apart and used two 9V batteries in succession to test each strip. One strip appears to be bad, as I could not get it to light up. Should I assume when one strip is bad, none will light up? If so, should I replace the one bad strip or all of them? Thanks for any help. As I said, I am a newbie with TV's, so any help would be appreciated.
#44 |
City & State: BC
My Country: Canada
![]() All the LEDs have wear and the ones still working are likely to fail. If you don't want a repeat failure, replace all of them with new and turn down the backlight level.
#45 |
![]() Thanks for the reply. Where is the best place to buy the LED's? How do you turn down the backlight level? Thanks for your help.
#46 |
City & State: BC
My Country: Canada
![]() Ordered these recently. They were a little bit thinner than the original strips so just taped them down with shipping tape. You can turn down the backlight in the picture settings menu. I would also turn off the ambient light sensor.
https://ebay.us/9AkX9X |
Thread Tools | |
Display Modes | |
