Hisense 55'' Issues Mainboard or Power Supply?
  • dabushar
    • Aug 2019
    • 23
    • Kenya
    Hi Guys, i have a tv i bought a mainboard for (a hisense 55H8E) because it just stopped working. When i replaced with the new motherboard. The TV comes on displays the logo and starts up fine.
    When i load or connect an input or play a youtbe video the backlight disappears but the audio and video remain. Anyone Experienced such? I have attached some pics of the old board the new board the power supply and the model.
    If anyone can assist id be grateful.
  • neilc6
    • Nov 2015
    • 1550
    Re: Hisense 55'' Issues Mainboard or Power Supply?
    Any issue with the backlight is usually the LEDs failing or intermittent. You can try turning down the backlight level and see if they stay on longer. Running at 100% is what causes them to fail.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4297
      • Italy - Milan
      In the options menu try to disable something like "dynamic dimming" or similar, then retry with your videos... but still a leds problem remain..
      • Diah
        • Feb 2013
        • 6357
        this had nothings to do with backlight issue.... hisense had option only audio.. to cut off BL. and widwine key for youtube content.. so..
        yours replacement boards belong to different model.. size.. need to write firmware again by downgrade and then upgrade to register yours screen and T-CON. or try first with service menu option ( Clear Flash )
        its so easy from the photo you can see the replacement boards had double ram.
        • dabushar
          • Aug 2019
          • 23
          • Kenya
          Re: Hisense 55'' Issues Mainboard or Power Supply 55H8E?
          Thanks @Diah, The replacement board is the exact same but a diffrent region, the board is from the US. The Original is from Africa/MiddleEast. SO i think therein lies the problem. I think the replacement board is draawing to much current from the power supply and since the inverter cant handle it, it drains the mosfets below thus shutting off the backlight.
          I was looking at the power supply for the US Hisense and its different. I think thats why its not working as it should. I have attached it.
          My Question now is: Can i lift the IC's from the new board and change the ones i have circled on the new board. My guess is the TCON is the one that died and since its on the mainboard the whole board will not work.
          If i transplant the IC's, Would the old board work? Or is the something else that should be replaced too?
          Thank you
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4297
            • Italy - Milan
            The top one is an audio.amplifier, the other ones can't be focused well with so an unclear photograph. the theory of the different drawn of power supply in mainboards is not realistic for me, the boards differences are very little in electrical level, i think and i'm convinced, you have a bad led intermittent. It is not easy.to diagnose this way but the only way like i did is to let the tv run at the lowest level backlight and wait when it no more light up, then.test every led.
            • dabushar
              • Aug 2019
              • 23
              • Kenya
              With the Replacement Board the TV starts very well, Backlight only disappears when you try any load (hdmi,aerial,youtube) When you restart the TV It starts up fine. Sorry about the bad photos. What i know about the leds is one is bad they all dont light up.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4297
                • Italy - Milan
                If the video input requests more light since it's a dynamic dimming maybe, then an half shorted led goes short circ. Check for the PSU connector signals to force the bl-on whitout a mainboard.
                • Diah
                  • Feb 2013
                  • 6357
                  Thanks @Diah, The replacement board is the exact same but a ......If i transplant the IC's, Would the old board work? Or is the something else that should be replaced too?
                  Thank you
                  Short answer NO. !!! are you going to develop Main boards !!
                  you have now just issue with soc I2C address which its designed & a signed by firmware.. so..
                  1-before we lost in BL subject.. you need to tell me whats wrong / Fault you have with yours original main boards..
                  2- with out any source ..log in your service menu and upload photo on pages:
                  A-Design - MAINCHIP SSC
                  B-Design- DRC & PAGAIN
                  3- check on Factory page all Key written and marked with OK
                  • Diah
                    • Feb 2013
                    • 6357
                    Thank you
                    NO. different NAND / RAM = different soc I2C at firmware.
                    • dabushar
                      • Aug 2019
                      • 23
                      • Kenya
                      I removed the heatsinks and took a better photo. I have shared the photo below..
                      Original - https://ibb.co/C6YdvVk
                      Replacement - https://ibb.co/NSFJJCX
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4297
                        • Italy - Milan
                        No different nand / ram... only cpu heatsink mounted in different way that covers chips.
                        • dabushar
                          • Aug 2019
                          • 23
                          • Kenya
                          What if i give the backlight a signal and another direct inverter so that when switched on the backlight comes on irregardless of the source on the power supply.?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4297
                            • Italy - Milan
                            I don't undrrstand, do what i have suggested earlier.. if you are not familiar post the silkscreened table of the pins on the power supply..
                            • Diah
                              • Feb 2013
                              • 6357
                              original set A6100 series replacement boards come from H8000 series.. hisense not so dumm to sell TV witj just heatsink flip up.... we are not judging by looking on beautiful woman with same eyes and lips... but the hearts (FW) are different. this why i asked to see her hearts value. LOL
                              • nomoresonys
                                • 12116
                                • U.S.
                                Save yourself from pulling all your hair out and just get the correct mainboard.
                                • dabushar
                                  • Aug 2019
                                  • 23
                                  • Kenya
                                  Yes, I think i will just have to get the correct mainboard for the A6103.. I saw the power supply for the american version and it's totally different. So the structuring of the backlights is very different, so my power supply wouldn't suffice. Even if I add an external inverter, it still would have some issues, Thanks for the help. You guy's are awesome..
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4297
                                    • Italy - Milan
                                    When you will spend extra money for a new board and you will see that is not enough? And with a test of few minutes you have the answer maybe.. testing the BL can be a very easy task.. i don't understand you.
                                    • dabushar
                                      • Aug 2019
                                      • 23
                                      • Kenya
                                      I already tested the backlight, i tested the board off the TV with other BL strips. Its shuts down.. I took photos of the TV working and loading content below
                                      https://ibb.co/KzqLTrm
                                      https://ibb.co/56Z3NtF
                                      https://ibb.co/S72Zqw2
                                      https://ibb.co/mR1fjmk
                                      https://ibb.co/LtJrN8C
                                      https://ibb.co/pJj1tHB
                                      So problem is the different mainboard... Below is its power supply..
                                      https://www.ebay.com/itm/Hisense-Pow...-/223495628051
                                      as you can see the power supply has an extra board on top for connection to backlight board.. Only found this recently
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4297
                                        • Italy - Milan
                                        ok this is a good test, so with external strips its shuts off after how much time or in which condition?
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • Jembang
                                          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                                          by Jembang
                                          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                                          11-01-2024, 09:55 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
