Old 11-01-2020, 02:06 PM   #1
Rufos86
City & State: tel aviv
My Country: israel
Default Samsung UA55EH6030MXSQ Bad LCD Display
hey all ,
one day me screen gone crazy , i searched google and youtube for solution and figured out its probably the T con board , i ordered a replacement board from ShopJimmy , replaced the one in my TV but nothing changed .
when i turn it on first it turns on , then off and then on.
i excamented the electronics and everything looks to be ok .
i put video on youtube showing the issue
https://www.youtube.com/watch?v=L3HoWrGYlwY
does any one have a clue what might be the problem and how to fix it ?
thanks
D
Rufos86 is offline   Reply With Quote
Old 11-01-2020, 04:11 PM   #2
neilc6
City & State: BC
My Country: Canada
Default Re: Samsung UA55EH6030MXSQ Bad LCD Display
Probably a bad panel and not repairable. You can power up the TV with only one side of the TV connected between the tcon and panel. If one side shows a good picture, the panel fault is on the bad side.
neilc6 is offline   Reply With Quote
Old 11-01-2020, 06:46 PM   #3
Kilroy2k1
City & State: Ontario Canada
Could be a bad cap or resistor on the panel driver boards.
Kilroy2k1 is offline   Reply With Quote
Old 11-01-2020, 11:30 PM   #4
Rufos86
My Country: israel
Hey , already tried it , disconnected one side and checked the screen and then did the same for the other cable , the result remain the same , there is no difference .
Old 11-01-2020, 11:58 PM   #5
Rufos86
My Country: israel
is that the board with all the connections HDMI etc ?
thanks
D.
Old 11-02-2020, 02:51 AM   #6
nomoresonys
City & State: midwest
My Country: U.S.
No, it's the thin board between the tcon and the panel.
nomoresonys is offline   Reply With Quote
Old 11-02-2020, 07:53 AM   #7
Rufos86
My Country: israel
thanks, ill check for shorts and update .
D.
Old 11-03-2020, 08:01 AM   #8
Robrokr
City & State: Liverpool
My Country: United Kingdom
I have had a few power cycle and freezing the nand chip to -40 will give you enough time to update the system, I'm on a ue55d now and it was doing the same but wasnt the nand chip it was a bad connection on the led board and the power ic was shutting it down. When it boots switch off all the lights and video the screen and check all sections are lit.
Robrokr is offline   Reply With Quote
Old 11-03-2020, 01:46 PM   #9
Rufos86
My Country: israel
hey , thanks for the tip.
can you explain that ? didn't really get it
and what exactly is the nand chip ? is it the one on the t con board ?
how eventually did you manged to fix your TV ?
thanks
D
Old 11-03-2020, 06:23 PM   #10
Robrokr
Saying that just looked your picture and it looks like the ribbons attached to the bottom off tor lcd panel might have come unstuck abit, try pressing on them with a plastic card and see if that helps.
Old 11-06-2020, 04:49 AM   #11
Rufos86
My Country: israel
hey all , just finished checking the TV - Again .
no shorts on any of the components on the LCD panel board .
cleaned the ribbon cable connectors with ipa .
disconnected one side and then the other side .
t-Con replace with new one
checked all the connectors for burn marks
i really don't know what else might be the problem . should i just get a new TV and that's it ?
thats how it looks now with the chromecast connected
Badcaps.net Technical Forums 2003 - 2021
