Panasonic SA-HT820V Home Theater System
  • CapsDude
    • Jan 2021
    • 50
    Re: Panasonic SA-HT820V Home Theater System
    Originally posted by R_J
    200ma 200v would be the minimum, that -30v supply is fairly low current, so any fast recovery diode greater than 200ma/200v would work.
    Ok, I'll get some and try it out. I appreciate your help so far.
    • CapsDude
      • Jan 2021
      • 50
      Got the part and soldered it. Nothing shows up on the display. It powers up tho because the vhs side starts up. The connector tape is fine.
      • R_J
        • 9535
        And the voltage is?
        • CapsDude
          • Jan 2021
          • 50
          And the voltage is?
          Pin number 6 is reading .6V. All other pins are good.
          • R_J
            • 9535
            Without -30 volts you won't get a display. To make sure there are no shorts on that line, CARFULLY remove the flat cable from P1102 and check if the negative -30v is on TL1030, if not, Unplug the unit and check the resistance of TL1030 to ground, it should be very high. Then as a last check, measure the transformer winding resistance It can be checked between D1270 cathode and ground (W56)
            • CapsDude
              • Jan 2021
              • 50
              Didn't get -30 on TL1030.
              TL1030 read 7.8 M Ohms
              D1270 read 4.6 M Ohms
              • R_J
                • 9535
                If D1270 cathode (white band) to ground measures 4.6M Ohms you either damaged a trace or the transformer winding is open.
                • CapsDude
                  • Jan 2021
                  • 50
                  Any way to find out if it's either one of those?
                  • R_J
                    • 9535
                    Nope, no way to tell
