EPK50 LA-G073P Bios dump need
    Hello friends, i have a HP 15-da0002la with motherboard EPK50 LA-G073P rev 1.0, with the next error code, the caps lock blinks 5 times slow and then 3 times quickly, does somebody have the bios dump of this machine? or does somebody have more information about this error code ? thanks a lot.
    Re: EPK50 LA-G073P Bios dump need
    try...
      Did you solve it, i have sam issue
        Remove all accessory devices from the notebook.
        https://support.hp.com/us-en/document/c01732674
          Originally posted by peste View Post
          try...
          Thank you sire.
            Mine does the exact same thing, just took out the MOBO found some rusted CAPS below the CPU
            I've cleaned them, checked the Tension fall on BIOS seems ok, let's cross fingers
              HP Notebook 15-da0019la (EPK50 LA-G073P)
              Hi, dear friends!
              Computer: HP Notebook 15-da0019la
              MoBo: EPK50 LA-G073P Rev: 1.0
              BIOS chip: XMC QU64AHIG
              I have this laptop with a frozen BIOS because of a Windows update. I already tried to reprogram the flash memory with a EZP2019 programmer (the autodetect doesn't work for the chip, so I used the W25Q64 chip option at 6 MHz, but not sure if this is correct way), unfortunaley, when I turn on the laptop it just blinks the code 5.3 in the caps lock.
              Besides, I found out that at the HP site for the model there is a software tool (https://support.hp.com/us-en/drivers...model/21909979) that extracts the BIOS file, but there are 6 different bin files (3 with 16MB size and the other 3 with 8MB size) plus another 6 files with .s12 extension (with the same names as the bin and 1KB size each one), with these names:
              084A6 -- 8MB
              084A8 -- 8MB *
              084AA -- 8MB *
              086B3 -- 16MB
              086C1 -- 16MB
              08532 -- 16MB
              According to the BIOS chip, I need an 8 MB file, so I tried with those marked with an * from the previuos list. But it didn't work, just the appear the blinking code again. I'm here to see if anyone could share the correct BIOS file (or a dump from the same laptop model), or if really worth it to try with the last 8 MB file; beacause I already de-soldered the chip twice. So, I think this is my last chance before a possible damage to the MoBo.
              I really apreciate your comments and help!
                Re: HP Notebook 15-da0019la (EPK50 LA-G073P)
                If you made a bios backup post it here .
                  Yes, I did a BIOS backup of the chip. Here is the dump file, but the laptop didn't start with that BIOS.
                    I have the same problem, which they have been able to solve, thanks
                    Last edited by SMDFlea; 04-05-2021, 10:52 AM. Reason: https://translate.google.com
                      How did you solved it? Did you reprogram your chip with another BIOS file?
                        did u get the file?
                          Originally posted by el panke View Post
                          did u get the file?
                          using hxd,you can see what is the MB bid.
                            i mean if he found the bios file that fixs it
                            the file posted here doesn't work
                              The bios file posted here won`t work,its corrupt,also its been booted on another machine its "initialised" . Clean ME/TXE firmware will be in a "Configured" clean state. You can check it for yourself with MEAnalyzer - https://github.com/platomav/MEAnalyzer/releases
                              Post your original bios backup if you have one .
                                heres bios backup
                                hp 15 da0051la
                                  Your bios BID is the same as the OP , BID084AA .The link to the bios is in the first post,run the exe to copy the 8MB 084AA.bin .Program the bios, then enter your DMI info using wndmifit/HP Bios config utility .
                                    HP 15-da0044nm (4RM58EA)
                                    Processor: Intel Pentium Silver N5000, nVidia GeForce MX110,
                                    KB 9022q
                                    please for bios + EC
                                    thanks in advance
                                      Hp 15-da epk50 la-g073p
                                      KB 9022q
                                      thanks in advance
                                      My old bios
                                      PS:There are some bios on the forum but none are for this model I listed.
                                        Re: Hp 15-da epk50 la-g073p
                                        Try and give feedback
