ME Firmware Cleaning Guide
    Re: ME Firmware Cleaning Guide
    how about Gen10? gen 11?
      How about it.What are you asking exactly.The win-raid guide has everything you need to know .
        some one can share solution clear ME 14.0.xx 15.0.xx for gen 10, gen 11?
          See this channel , hepful informations
          https://www.youtube.com/watch?v=x_PjZyJ_BSQ&t=98s
            thank you. i have done
              i Have a problem when i extract the file the me region is 4.78mb but the cleaned me is 7.0mb
              so what is the problem
                Re: HP 840 G1 is not in committed state
                @SMDFlea i want to know something.How i replace in Me Region MFS/FTPR/NFTP area.
                According to this video.He doing auto how i can manually.
                link video
                Time 01:12:40 MFS CHUNK DATA CLEAN
                https://www.youtube.com/watch?v=j2K5PHqZunk
                  link video
                  You can check with MEAnalyzer how the partitions are laid out and the start and end addresses and size using the -dfpt switch .You can use a hex editor and UEFITool (newer version) to see the partitions use the extract as-is if you want to copy any part from one ME region to edit into another. You can even edit the PCHC,PMC partitions
                    Can you share UEFI tool which version show me partition.
                      I`m using A57 https://github.com/LongSoft/UEFITool/releases
                        As this thread has gone off topic i`ll move the posts to the ME FW cleaning guide thread
                          please i need flash image tool V 12.0.32.1421
                            The FIT tools version doesn`t have to match exactly, as long as its version 12 its ok (version 12 ME firmware,use version 12 of FIT). The link to the tools is in the first post, along with the win-raid guide
                              i do it with version 12 but the hdd becomes not detectable in setup
                                Post a picture ,i don`t understand what you mean
                                  i do clean me region to the bios and i flash pc but hdd becomes not detect in setup and when i flash with the old bios the hdd is detected
                                  the new bios cleared is in the picture
                                    Maybe you did something wrong. Post your original bios backup in a new thread,not in this thread please - https://www.badcaps.net/forum/forumdisplay.php?f=40
                                      need Intel CSME firmware repository pack for 11.8.83.3874
                                        The links to the firmware repositories are in post #1 .If an exact production region firmware isn`t available its ok to use the nearest older or newer one instead.
                                          Thank you for sharing this article. Thank you, my friend
