I have a Asus B250 mining expert mother board that does not post,
it turns on, CPU fan and LED is on, no buzzer sound, and reboots after 25 seconds or so.
The components have been tested in another of the same model motherboard.
no visible issue at all
cpu pins are good , capacitors look good
but when I was testing continuity of all capacitors on circuit using regular multimeter , I found one that has continuity while all other did not,
so I checked the same capacitor on a working motherboard and see that it is not supposed to have continuity.
so I decided to take it out and see if the motherboard runs,
unfortunately it did not fix it with the capacitor removed...
Does that mean I have another issue beside the capacitor?
I was going to order
what are the chances that replacing that capacitor will fix it...
blue dot close to the place capacitor was removed
Code:
Wurth Elektronik 865250157010 mouser.com/ProductDetail/710-865250157010
