Picked this up today probably should have known better. Will show pic of screen when I got it home. Took back off and saw a red wire from the PSB disconnected as if it had been pulled out of the harness connector as the pin connector was still in the harness connector that goes to the T-Con. That pin connector is labeled SCLK, ( serial clock)? Anyway it made no difference when connected.
I know this TV has major concerns with the Main board. I have all the power board voltages and it fires right up and that is all she does. Got the 12 volts to the T-Con. Disconnected each ribbon cable to the LCD and they alternated from white on side and black on the other. Anyone have an idea on this?
