Another Shuttle MV19 saved
    A Short story: Before recaping, I can't even instal windows (98se, me) with this board. I opened the case, found 7 Gloria 2700uF caps had bulged (all of them!) and leaking. 1 caps near CPU even had been shorted. Good thing that it didn't destroyed the VRM. Well actually i didn't know this board was still good until i've recaped it.
    Actually i found no problems with DS caps, but i replace them anyway. I leave 3 DS caps arround PCI slots, test with a LAN card and a tv card, no probs.
    This board is worth recaping because it has onboard vga (S3) and agp slot, support intel 1.13GHz proc.
    I checked the PSu and sure it has JEE and Rulycon caps bulged. The owner refused to buy a new good PSU (i recomend him a cheap silverstone PSU). Alright i also recaped the PSu with some MBZ and WG caps. Overkill i must said but that's only what i have.
    Everything runs fine, the bench/test, the onboard features and the os/sw installation. I test it with 1 GHz proc it's no prob.
    Sorry no pics for the PSu (Scorpions 300W ATX) and Gloria caps.
    Ps. This is the #5 MV19 boards i've recapped . In earlier day when finding a good 10mm caps was so damn difficult, i replaced the 3300uF ones with 1500uF MBZ. It worked for P3 600MHZ but not for P3 1GHz. I also used some odd ways (soldering the additional caps from below the mobo, but the case need to be moded. Way too hassle for my friends.)
    days are so short when you actually do something..
    Re: Another Shuttle MV19 saved
        Nice job, but why are the PCI slot covers missing?
        The great capacitor showdown!
          for the ventilation, i believe it has very poor ventilation, or it was used for larger mobo..
            just last week the user reported that he saw one of the "DS" cap bulging. crap. I immediately replaced all three of them, 1000uf 6.3v DS caps with chemicon KZG 820uf 6.3v 8mmx11.5mm.
            actually there was just no problem before and after the second recaping. i just have thought any bulging caps are not good.
              D.S Capasitor
                Originally posted by yanz
                D.S Capasitor
                Another bad cap manufacturer using Rubycon's K vents.
                That Scorpions PSU must have been made by POWMAX.
                POWMAX is the only PSU manufacturer I know using JEE and Rulycon capacitors.
                My gaming PC:
                AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                ASUS M4A77TD AMD 770 AM3 Motherboard
                PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                ASUS Xonar DG 5.1 Channel PCI sound card
                Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                Antec Three Hundred Mid-Tower Case
                Microsoft Windows 10 Pro 64-bit
                Microsoft Windows 7 Ultimate SP1 64-bit
                  may be you're right, it has a resemblance of a powmax kc8adu has posted in psu section. this psu has "wannien" printed on the pcb though.
                  i don't know why i waste my good caps on this crap:
                    it's been replaced with an ilssan psu (200W, recapped), a good old korean psu.
                      Gloria caps that was on MV19 board:
                        gloria are disgusting caps
                          Yeah, Gloria tends to blow out its bottom plugs, making failure harder to detect. Always replace all of them, regardless of condition.
                            Note that the D.S. caps as mentioned in this thread appear to be same (brand at least) as those "SG"-marked caps 'pinobot' had found pre-blown, as it were, on his SV24/FV24. https://www.badcaps.net/forum/showthread.php?t=1590
                            They could prove a worthy match for Chhsi for the title of "worst cap brand of all time".
