Hello guys,
Im new here on forum but also in all this, a total newbie, so please have some mercy
The laptop Im trying to repair is:
Model: Compaq Presario CQ71-411EG
Product: VX896EA#ABD
CPU: Intel Core 2 Duo T6600 / 2.2 GHz
Graphics: NVIDIA GeForce G103M - 512 MB
Motherboard:
The problem Im having is that the laptop wont turn on at all. When I connect the power adapter the LED of the power jack turns on for about 5 - 10 seconds and goes off, thats all I get, no other sign of life.
I did some research on the forum and found a pretty similar case with the same symptoms Presario CQ61 Dead- Not Booting - by nogger
I decided to make a new thread because its not about the same laptop (but same motherboard) and not the same BIOS, i guess.
Now back to my problem,
This is what I have checked so far:
After doing all the tests I came here and found the problem with BIOS which I assume is also mine problem.
I need your help to choose the BIOS and find it, I tried to find it but without success, couldnt find anything on HPs site.
First of all, I would like to know is if I can use the same BIOS as the one for Presario CQ61 because that one is available in the thread I shared and the laptops have the same motherboard.
Edit: I found the BIOS for my laptop. The file name is the same as the BIOS file for CQ61, so I guess I could use the BIOS from the other threat too.
Second thing is, where can I find the software for BIOS programming, or does the software come together with the programmer I purchase? For the serial number after the reprogramming I understood that I have to use the HP DMI tools which I already downloaded and have them ready. Not quite sure how to use it yet but I will google it.
And the last thing is, which programmer to buy. I cant spend much money so if some Chinese cheap ones can do the job I would be happy with it. Would this one be alright? High-Speed USB SPI Programmer EZP2010
Thanks a lot in advance guys!
Motherboard:
- DA00P6MB6D0
- PCB 0P6 MB
- REV D
- Measured the voltage going into the motherboard and I got close to 19 volts so I assume the power jack is alright.
- I checked the power button with my multi-meter for continuity and well I got the beeping so I would assume its not the power button either. Best would be to test it with a new power button, i know. However, I somehow doubt that the power button is the problem.
- Now that I know its not the power button (most probably) nor the power jack I tested the voltage in other chips. I didnt know which exactly to test because I dont have the diagram but even with it I dont think I would be able to read it correctly. However, I tested almost all of them and in some I had 18+v volts, in some 5+ volts, some with 3+ volts. Those close to the power jack and battery seemed to be fine, so I guess the power is fine.
- Knowing that its none of the above I removed the hardware from the motherboard one by one to see if maybe some of it is causing the problem. Firstly i removed the battery, then HDD, then the RAM Memory, DVD, USB board, audio board and the speakers,mouse board, wireless card, again it didnt power up, guess these arent causing the problem either.
